[petsc-dev] Problem with petsc-dev
    Keita Teranishi
    keita at cray.com
    Fri Aug 27 13:28:55 CDT 2010
Barry,
I already see a big difference in MatMult routine of ksp/ksp/examples/tutorials/ex2.c, and I am very happy to try that example program.
 Keita Teranishi
 Scientific Library Group
 Cray, Inc.
 keita at cray.com
-----Original Message-----
From: petsc-dev-bounces at mcs.anl.gov [mailto:petsc-dev-bounces at mcs.anl.gov] On Behalf Of Barry Smith
Sent: Friday, August 27, 2010 1:13 PM
To: For users of the development version of PETSc
Subject: Re: [petsc-dev] Problem with petsc-dev
   You can run, for example, src/snes/examples/tutorials ex19 with the options -pc_type jacobi -dmmg_nlevels 5  -da_vec_type cuda -da_mat_type aijcuda  and run without those last two options to NOT use the GPU and compare the results with -log_summary. We'd be interesting in seeing those numbers also.
   Barry
On Aug 27, 2010, at 1:07 PM, Keita Teranishi wrote:
> Satish,
> Now I got the latest copy using mercurial.  Thanks!
> I am going to check the performance with Fermi.  Is there any command line option available to swith CUSP? Or do I have to apply MatConvet() with PETSc function calls?
> Thanks,
>  Keita Teranishi
>  Cray, Inc.
>  keita at cray.com
> From: petsc-dev-bounces at mcs.anl.gov [mailto:petsc-dev-bounces at mcs.anl.gov] On Behalf Of Satish Balay
> Sent: Friday, August 27, 2010 11:14 AM
> On Fri, 27 Aug 2010, Keita Teranishi wrote:
>> Satish,
>> Thanks.  I do not see any mercurial package for SUSE, let me try if it works.
> source install of mercruial is pretty easy
> cd mercurial
> python setup.py install --prefix=/foo/bar
> [instructions say - use PYTHONPATH - but I like to hardcode it in 'hg'
> script] i.e edit /foo/bar/bin/hg and add the following at the very
> begining [where mercurial uses a different value of pythonXX -
> depending on the python version on your machine]
> import sys
> sys.path.insert(0,'/foo/bar/lib/pythonXX/site-packages/')
> Satish
