[petsc-dev] Problem with petsc-dev
Barry Smith
bsmith at mcs.anl.gov
Fri Aug 27 13:12:30 CDT 2010
You can run, for example, src/snes/examples/tutorials ex19 with the options -pc_type jacobi -dmmg_nlevels 5 -da_vec_type cuda -da_mat_type aijcuda and run without those last two options to NOT use the GPU and compare the results with -log_summary. We'd be interesting in seeing those numbers also.
Barry
On Aug 27, 2010, at 1:07 PM, Keita Teranishi wrote:
> Satish,
> Now I got the latest copy using mercurial. Thanks!
> I am going to check the performance with Fermi. Is there any command line option available to swith CUSP? Or do I have to apply MatConvet() with PETSc function calls?
> Thanks,
> Keita Teranishi
> Scientific Library Group
> Cray, Inc.
> keita at cray.com
> -----Original Message-----
> From: petsc-dev-bounces at mcs.anl.gov [mailto:petsc-dev-bounces at mcs.anl.gov] On Behalf Of Satish Balay
> Sent: Friday, August 27, 2010 11:14 AM
> To: For users of the development version of PETSc
> Subject: Re: [petsc-dev] Problem with petsc-dev
> On Fri, 27 Aug 2010, Keita Teranishi wrote:
>> Satish,
>> Thanks. I do not see any mercurial package for SUSE, let me try if it works.
> source install of mercruial is pretty easy
> cd mercurial
> python setup.py install --prefix=/foo/bar
> [instructions say - use PYTHONPATH - but I like to hardcode it in 'hg'
> script] i.e edit /foo/bar/bin/hg and add the following at the very
> begining [where mercurial uses a different value of pythonXX -
> depending on the python version on your machine]
> import sys
> sys.path.insert(0,'/foo/bar/lib/pythonXX/site-packages/')
> Satish
