[petsc-dev] What's the point of D(A/M)GetGlobalVector?
    Barry Smith
    bsmith at mcs.anl.gov
    Fri Aug 27 12:49:30 CDT 2010
  Hmmm,
petscda.h:EXTERN PetscErrorCode PETSCDM_DLLEXPORT  DMGetColoring(DM,ISColoringType,const MatType,ISColoring*);
petscda.h:EXTERN PetscErrorCode PETSCDM_DLLEXPORT  DMGetMatrix(DM, const MatType,Mat*);
petscda.h:EXTERN PetscErrorCode PETSCDM_DLLEXPORT  DMGetInterpolation(DM,DM,Mat*,Vec*);
petscda.h:EXTERN PetscErrorCode PETSCDM_DLLEXPORT  DMGetInterpolationScale(DM,DM,Mat,Vec*);
petscda.h:EXTERN PetscErrorCode PETSCDM_DLLEXPORT  DMGetAggregates(DM,DM,Mat*);
   should all of these be Create?
   In my mind usually Get means get something intrinsic to the underlying object (some property of it for example);  Create means generate a new thing that while it may be associated with the DA is not "owned" or "controlled" by the DA.
    Another way to organize is Create() implies you later Destroy() that object, while for things you Get you do something else (like restore).
    I'm inclined to change all of these ones to Create() since they are all Destroyed()
   Barry
On Aug 27, 2010, at 11:10 AM, Jed Brown wrote:
> On Fri, 27 Aug 2010 12:00:32 -0400, Kai Germaschewski <kai.germaschewski at unh.edu> wrote:
>> And it also requires some more memory management framework which would
>> call upon caches to expire long-unused objects when memory is running
>> low.
> How would you detect this?  Note that further allocation may be done
> external to PETSc, and perhaps even in a separate process.  We're not in
> a managed environment, we can't get a reliable "time to GC".  If we
> could get that sort of signal, then I would be for such caching at all
> times, but I don't think we can, in which case I still think
> managed/pooled access versus owned creation needs to be explicitly
> different.
> Jed
