[petsc-dev] Problem with petsc-dev
    Keita Teranishi
    keita at cray.com
    Fri Aug 27 10:48:52 CDT 2010
Satish,
Thanks.  I do not see any mercurial package for SUSE, let me try if it works.
 Keita Teranishi
 Scientific Library Group
 Cray, Inc.
 keita at cray.com
-----Original Message-----
From: petsc-dev-bounces at mcs.anl.gov [mailto:petsc-dev-bounces at mcs.anl.gov] On Behalf Of Satish Balay
Sent: Friday, August 27, 2010 10:33 AM
To: For users of the development version of PETSc
Subject: Re: [petsc-dev] Problem with petsc-dev
There was a problem with tarball creation for the past few days. Will
try to respin manually today - and update you.
If using petsc-dev - its best to use mercurial though..
Satish
On Fri, 27 Aug 2010, Keita Teranishi wrote:
> Satish,
> I still have the same error with the tar ball I downloaded several minutes ago.
> Regards,
>  Keita Teranishi
>  Cray, Inc.
>  keita at cray.com
> Sent: Thursday, August 26, 2010 11:15 PM
> tonights tarball should have a fix for this.
> satish
> On Thu, 26 Aug 2010, Keita Teranishi wrote:
> > I downloaded a nightly tar ball.
> >  Keita Teranishi
> >  Cray, Inc.
> >  keita at cray.com
> > Sent: Thursday, August 26, 2010 10:33 PM
> > Do you obtain petsc-dev via nightly tarball - and not mercurial?
> > > Hi,
> > > I haven't been able to run the configure script of petsc-dev.  The error message is, "No module named cmakegen."  What does the message mean?
> > > Thanks,
> > >  Keita Teranishi
> > >  Cray, Inc.
> > >  keita at cray.com
