[petsc-dev] no module named cmakegen
Mon Aug 23 17:18:50 CDT 2010
On Mon, 23 Aug 2010, Jed Brown wrote:
> On Mon, 23 Aug 2010 16:58:57 -0500 (CDT), Satish Balay <balay at mcs.anl.gov> wrote:
> > config/install.py is an exaple of stand alone script requiring
> > PETSC_DIR/PETSC_ARCH - it also relies on being invoked in PETSC_DIR
> Do you suggest copying it's first 25 lines into all new scripts?
I guess thats the current recomendation.
>From previous edits - Barry doesn't like these provided as command
line arguments to the stand alone scripts.
There is also config/builder.py - that doesn't work witout PETSC_DIR
env variable.
And I don't like over reliance on evn variables - when its not needed
- esp for build tools. These give rise to undebuggable errors [wrong
buildsytem used from a different PETSC_DIR source tree etc - or
generated files are dumped into the wrong PETSc tree etc....]
Also we are opposed to CC CFLAGS etc in env variables. So in that line
of things PETSC_DIR/PETSC_ARCH reliance should also be minimised -
[avoided - when not needed]
Now that there are more and more standalone scripts - perhaps we need
a better consistant way to handle this - but I don't know what that
is..
Satish
> > Part of the issue with PETSC_DIR/PETSC_ARCH is: they are primarily
> > needed by 'makefiles' [for both building and using PETSc]. All other
> > build tools - hopefully don't need them - or can autodetect as needed.
> FWIW, the CMake build doesn't use them anywhere.  I just don't like
> copying the autodetection all over the place.  The trouble is that even
> after wrapping up the autodetection, we still have to find it.
