[petsc-dev] no module named cmakegen
    Matthew Knepley
    knepley at gmail.com
    Mon Aug 23 17:11:49 CDT 2010
On Mon, Aug 23, 2010 at 10:09 PM, Jed Brown <jed at 59a2.org> wrote:
> On Mon, 23 Aug 2010 16:58:57 -0500 (CDT), Satish Balay <balay at mcs.anl.gov>
> wrote:
> > config/install.py is an exaple of stand alone script requiring
> > PETSC_DIR/PETSC_ARCH - it also relies on being invoked in PETSC_DIR
> Do you suggest copying it's first 25 lines into all new scripts?
> > Part of the issue with PETSC_DIR/PETSC_ARCH is: they are primarily
> > needed by 'makefiles' [for both building and using PETSc]. All other
> > build tools - hopefully don't need them - or can autodetect as needed.
> FWIW, the CMake build doesn't use them anywhere.  I just don't like
> copying the autodetection all over the place.  The trouble is that even
> after wrapping up the autodetection, we still have to find it.
I guess it comes down to what horrifies you more:
  a) Changing the Python installation (I hate this)
  b) Having 25 lines of boilerplate in every toplevel script
  c) Requiring that you run it in a known place (Jed hates this)
     Matt
> Jed
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20100823/5bc97379/attachment.html>
