[petsc-dev] no module named cmakegen
    Satish Balay
    balay at mcs.anl.gov
    Mon Aug 23 16:58:57 CDT 2010
On Mon, 23 Aug 2010, Jed Brown wrote:
> On Mon, 23 Aug 2010 16:18:27 -0500 (CDT), Satish Balay <balay at mcs.anl.gov> wrote:
> > Well currently configure is to be invoked in PETSC_DIR - and the py scripts
> > generally use relative paths to find each other. For eg: config/configure.py has:
> >   # Should be run from the toplevel
> >   configDir = os.path.abspath('config')
> >   bsDir     = os.path.join(configDir, 'BuildSystem')
> Right, and self.petscdir is set regardless of whether the environment
> variable PETSC_DIR has been set.  The trouble comes when you invoke a
> script (that could be run stand-alone, even if that is advanced usage).
> Even if you didn't mind requiring that PWD be chosen carefully before
> calling the maintenance script (which I find ugly), we still don't want
> to copy all the environment checks and error handling from configure.py,
> but we can't find *any* PETSc modules without knowing PETSC_DIR or using
> the relative path hacks.
> In this case, the script has to be able to "import script" before the
> PETScMaker type can be declared.  Maybe the right thing to do is to move
> the whole class definition into cmakeboot.main() which acquires petscdir
> as an explicit argument, and can thus set things up correctly.
> Any comments/suggestions on what I currently have in cmakeboot.py?
>   def main(petscdir, petscarch, argDB=None, framework=None, logPrint=printFunction, args=[]):
>     # This can be called as a stand-alone program, or by importing it from
>     # python.  The latter functionality is needed because argDB does not
>     # get written until the very end of configure, but we want to run this
>     # automatically during configure (if CMake is available).
>     # Strangely, we can't store logPrint in the PETScMaker because
>     # (somewhere) it creeps into framework (which I don't want to modify)
>     # and makes the result unpickleable.  This is not a problem when run
>     # as a standalone program (because the database is read-only), but is
>     # not okay when called from configure.
>     PETScMaker(petscdir,petscarch,argDB,framework).cmakeboot(args,logPrint)
> Note that cmakeboot.py can be called independently after configure, it
> does not modify argDB at all, but I have it running during configure
> just so that users of the cmake build don't have any extra steps to
> remember (just configure as usual, the run make from the build
> directory).
config/install.py is an exaple of stand alone script requiring
PETSC_DIR/PETSC_ARCH - it also relies on being invoked in PETSC_DIR
Part of the issue with PETSC_DIR/PETSC_ARCH is: they are primarily
needed by 'makefiles' [for both building and using PETSc]. All other
build tools - hopefully don't need them - or can autodetect as needed.
Satish
