[petsc-dev] PETSc ./configure request to build shared libraries is failing silently in petsc-dev (changeset: 16780:e7052ddd3def)
Aron Ahmadia
aron.ahmadia at kaust.edu.sa
Mon Aug 23 13:42:57 CDT 2010
Hi Lisandro,
The use case looks something like the following (this won't make sense if
you're not viewing in fixed-width):
PetClaw (Python code with main)
x------x--------x
PETSc4Py F90 kernels (through F2py)
Python is gluing all three x's, so the main driver is Python, and there is
no need to call Python from C. We are not currently considering any
extension modules besides what comes out of the box with PETSc4Py (Numpy)
I assume that I will still need all of the underlying libraries to be
compiled with PIC enabled.
I don't quite grok the difference between a static archive containing
PIC-compiled code and a dynamic library with same. It might not be too hard
to get a PIC-enabled xlc PETSc build, but I will stick to the working gnu
build for now.
Thanks for your help,
Aron
On Mon, Aug 23, 2010 at 6:18 PM, Lisandro Dalcin <dalcinl at gmail.com> wrote:
> On 21 August 2010 10:08, Aron Ahmadia <aron.ahmadia at kaust.edu.sa> wrote:
> > Hi PETSc developers,
> > As you may or may not know, we are planning on building PETSc4Py on our
> > BlueGene/P machine here at KAUST as core software for several research
> > projects that we are kickstarting this Fall, including a Pythonic
> > integration of PETSc into PyCLAW to (initially) manage multiprocessor
> > distributed memory domain decompositions using PETSc DA components. A
> key
> > component of this, of course, is getting PETSc4Py installed on our BGP,
> > something I am willing to take a serious effort at, but have not done
> > before. I am working from developer's copies of both PETSc and PETSc4Py
> in
> > anticipation of potential trouble, and I have a few tools here on the
> > BlueGene/P side that should simplify automating the installation once I
> have
> > successfully done it once :o)
> > I have successfully built PETSc4Py on a Linux workstation, so I am
> familiar
> > with the process. Of course, everything gets much uglier on a BGP. To
> > start with, the PETSc install file that comes as an example does not
> build
> > shared libraries out of the box.
> > Turning this switch on, however, does not appear to have any effect in
> > actually getting PETSc to build sharing libraries (or at least tell me
> why
> > it can't). I took a look through the configure log and couldn't find
> > anything that makes sense to me.
> > Thanks,
> > Aron
> How are you planning to use petsc4py? Are you going to embed Python in
> a C/C++ app? Is he core PETSc library going to be linked to other
> extension modules? I ask this because petsc4py do works with static
> libraries, moreover I managed to support static builds of PETSc and
> SLEPc/TAO and still get petsc4py and slepc4py/tao4py working fine (it
> only works on Linux, and likely on others POSIX systems excluding OS
> X). I do not promote this feature because novices usually make a mess
> when link Python modules with static libraries.
> Lisandro Dalcin
> CIMEC (INTEC/CONICET-UNL)
> Predio CONICET-Santa Fe
> Colectora RN 168 Km 472, Paraje El Pozo
> Tel: +54-342-4511594 (ext 1011)
> Tel/Fax: +54-342-4511169
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20100823/ece51fcb/attachment.html>
