[petsc-dev] no module named cmakegen
    Satish Balay
    balay at mcs.anl.gov
    Mon Aug 23 10:25:21 CDT 2010
1. you haven't mentioned the command you've invoked
2. you haven't sent the logfile as instructed.
All discussions without the above are just guessing games.  If you
want to make progress - run with the additional configure option
--with-cmake=0
Jed,
shouldn't the cmake output [when invoked via configure] - go into
configure.log - and not to stdout?.
Satish
On Mon, 23 Aug 2010, Leo van Kampenhout wrote:
> Hello, the problem with the "infinite" loop seems to be CMAKE related. Sorry
> to bother. Maybe the minimum required version of CMake should be changed
> from 2.6 to something higher.
> Here<http://www.mail-archive.com/cmake@cmake.org/msg25107.html>people
> discuss the same problem, where somebody suggest the problem of
> infinite looping is fixed in version
> 2.6.2<http://www.cmake.org/files/v2.6/CMakeChangeLog-2.6.2>
> regards
> 2010/8/23 Matthew Knepley <knepley at gmail.com>
> > This is not output from our configure. Are you running something else in
> > the PETSc directory?
> > Send configure.log
> >    Matt
> > On Mon, Aug 23, 2010 at 11:45 AM, Leo van Kampenhout <
> > lvankampenhout at gmail.com> wrote:
> >> Hi Aron,
> >> I try now to configure the Mercurial version of Petsc-dev. However, the
> >> script gets stuck in some kind of "infinite" loop, producing this text over
> >> and over again. What should I do now?
> >> -- The C compiler identification is GNU
> >> -- Check for working C compiler: /opt/local/bin/mpicc
> >> -- Check for working C compiler: /opt/local/bin/mpicc -- works
> >> -- Detecting C compiler ABI info
> >> -- Detecting C compiler ABI info - done
> >> -- The Fortran compiler identification is GNU
> >> -- Check for working Fortran compiler: mpif90
> >> -- Check for working Fortran compiler: mpif90 -- works
> >> -- Checking whether mpif90 supports Fortran 90
> >> -- Checking whether mpif90 supports Fortran 90 -- yes
> >> -- Configuring done
> >> You have changed variables that require your cache to be deleted.
> >> Configure will be re-run and you may have to reset some variables.
> >> The following variables have changed:
> >> CMAKE_Fortran_COMPILER= mpif90
> >> Leo
> >> 2010/8/23 Aron Ahmadia <aron at ahmadia.net>
> >>> Hi Leo,
> >>> Yes.
> >>> A
> >>> On Mon, Aug 23, 2010 at 2:19 PM, Leo van Kampenhout <
> >>>> Hi Aron,
> >>>> I'm using the nightly tarball. Do you propose using mercurial? I can try
> >>>> that.
> >>>> Leo
> >>>> Hi Leo,
> >>>>> Did you perform an "hg pull; hg update" in
> >>>>> petsc-dev/config/BuildSystem?
> >>>>> A
> >>>>> On Mon, Aug 23, 2010 at 2:14 PM, Leo van Kampenhout <
> >>>>>> Hi all,
> >>>>>> I'm trying to install PETSc-dev on my desktop machine. This is what
> >>>>>> goes wrong. I suspect the line
> >>>>>>  import cmakegen [line 409]
> >>>>>> in the configure.py is the cause. The version of Cmake installed on my
> >>>>>> system is 2.6
> >>>>>> Best regards,
> >>>>>> Leo van Kampenhout
> >>>>>> csg4035 at wingtip70:~/install/petsc-dev$ ./configure
> >>>>>>              Configuring PETSc to compile on your
> >>>>>> system
> >>>>>> TESTING: configureFortranFlush from
> >>>>>> PETSc.Configure(/net/users/csg/csg4035/download/petsc-dev/config/PETSc/Configure.py:652*******************************************************************************
> >>>>>>                      UNABLE to FIND MODULE for ./configure
> >>>>>> No module named cmakegen
> > What most experimenters take for granted before they begin their
> > experiments is infinitely more interesting than any results to which their
> > experiments lead.
> > -- Norbert Wiener
