[petsc-dev] Stop breaking my build
    Todd Munson
    tmunson at mcs.anl.gov
    Thu Aug 19 18:17:59 CDT 2010
There is probably an equivalent version of DVI for complex numbers, but I think you
can safely ignore it for now and only deal with reals.
Cheers, Todd.
On Aug 19, 2010, at 6:12 PM, Shri wrote:
> I'm not sure whether DVI should have support for complex type since complex variables with real upper and lower bounds don't make sense to me and i don't know of any actual problems which have or need complex bounds.
> ----- Barry Smith <bsmith at mcs.anl.gov> wrote:
>>  Shri,
>>    Since this is development code that only you are working on you can "protect" its use by putting a
>> #requirespackage  'PETSC_USE_DVI'
>> in the makefile in that directory and if you register the method in SNESRegisterAll() then protect it with
>> #if defined(PETSC_USE_DVI)
>> then define PETSC_USE_DVI in $PETSC_ARCH/include/petscconf.h
>> this way you can "be sloppy" but other people will still have access to your new stuff if they want it in the repository. Then later when the code is ready for general builds take out the ifdefs
> Ok. I've done this.
>>   Barry
>> On Aug 19, 2010, at 2:02 PM, Shri wrote:
>>>> Shri - looks like merit should be PetscReal - not PetscComplex [pusing
>>>> a fix for this. If this is incorrect - you can revert my change]
>>> That's correct...thanks.I am building petsc with complex right now to see if there are any other changes needed.
>>>> Satish
