[petsc-dev] Triangular solve on the GPU
Mon Aug 16 07:06:41 CDT 2010
I am no longer as pessimistic as I once was. To start, this is a good report
on prefix-sum in parallel:
  http://www.cs.cmu.edu/~blelloch/papers/Ble93.pdf
It can solve first-order recurrences optimally. Higher order recurrences can
be reduced to first-order,
however it is not work optimal (too big by a factor of the order, m), which
seems alright to me. Thus
we should be able to solve bandwidth m matrices efficiently. Here is a nice
implementation of prefix-sum
  http://code.google.com/p/cudpp/
This all leads me to believe that for a bounded number of nonzeros per row,
we can get an efficient
algorithm for triangular solve.
  Matt
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20100816/615d43d0/attachment.html>
