[petsc-dev] automatic preconditioners for Stokes type problems?
Matthew Knepley
knepley at gmail.com
Thu Aug 5 09:51:33 CDT 2010
On Thu, Aug 5, 2010 at 9:45 AM, Mark F. Adams <mark.adams at columbia.edu>wrote:
> Jed brings up good points about false negatives, there are also false
> positives to worry about. This is a bad idea, at least as a default solver.
I was not thinking about that at all. There would be no false positives
because the user would be required to
say "I have exactly this Stokes system, I am just too lazy to make my ISes,
please do it for me Magic PETSc".
Matt
> That said, there is work on "adaptive" solvers like bootstrap AMG and using
> machine learning to formalize what it sounds like Barry is driving at.
> Perhaps make a '-ksp_type black_box' solver type where you put any
> heuristics methods like this. (this would require the KSP method to change
> the PC method which is ugly...)
> Mark
> On Aug 5, 2010, at 5:36 AM, Matthew Knepley wrote:
> On Thu, Aug 5, 2010 at 2:10 AM, Jed Brown <jed at 59a2.org> wrote:
>> On Thu, 5 Aug 2010 00:21:13 -0500, Matthew Knepley <knepley at gmail.com>
>> wrote:
>> > If someone tells us, "I have a Stokes problem", we could search for 0
>> > diagonals and create the partition for FS.
>> I suppose this would work for some common cases, but there are lot of
>> discretizations and pressure-dependent constitutive relations/boundary
>> conditions that have nonzeros in the pressure block. I think some slip
>> conditions can also produce zero or negative values in the momentum
>> block.
> Do not disagree.
>> I'm not convinced that it's so much to ask people to provide an index
>> set, considering that FieldSplit is a somewhat advanced thing anyway
>> (based on sheer number of choices available, and (typical) sensitivity
>> to those choices).
> I guess the point here is somewhat like the point of DAs. It is a very
> limited
> thing, but something many people do. So we provide a way to most easily
> do the very limited thing.
> Not sure if this is useful enough, but it might be.
> Matt
>> Jed
> experiments lead.
> -- Norbert Wiener
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20100805/56a14420/attachment.html>
