[petsc-dev] automatic preconditioners for Stokes type problems?
Mark F. Adams
mark.adams at columbia.edu
Thu Aug 5 09:45:10 CDT 2010
Jed brings up good points about false negatives, there are also false
positives to worry about. This is a bad idea, at least as a default
solver.
That said, there is work on "adaptive" solvers like bootstrap AMG and
using machine learning to formalize what it sounds like Barry is
driving at. Perhaps make a '-ksp_type black_box' solver type where
you put any heuristics methods like this. (this would require the KSP
method to change the PC method which is ugly...)
On Aug 5, 2010, at 5:36 AM, Matthew Knepley wrote:
> On Thu, Aug 5, 2010 at 2:10 AM, Jed Brown <jed at 59a2.org> wrote:
> On Thu, 5 Aug 2010 00:21:13 -0500, Matthew Knepley
> <knepley at gmail.com> wrote:
> > If someone tells us, "I have a Stokes problem", we could search
> for 0
> > diagonals and create the partition for FS.
> I suppose this would work for some common cases, but there are lot of
> discretizations and pressure-dependent constitutive relations/boundary
> conditions that have nonzeros in the pressure block. I think some
> slip
> conditions can also produce zero or negative values in the momentum
> block.
> Do not disagree.
> I'm not convinced that it's so much to ask people to provide an index
> set, considering that FieldSplit is a somewhat advanced thing anyway
> (based on sheer number of choices available, and (typical) sensitivity
> to those choices).
> I guess the point here is somewhat like the point of DAs. It is a
> very limited
> thing, but something many people do. So we provide a way to most
> easily
> do the very limited thing.
> Not sure if this is useful enough, but it might be.
> Matt
> Jed
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20100805/7e275749/attachment.html>
