[petsc-dev] DAGet[Ghosted]Coordinates and refcounts
    Lisandro Dalcin
    dalcinl at gmail.com
    Mon Aug  2 20:43:37 CDT 2010
On 2 August 2010 18:36, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Aug 2, 2010, at 4:31 PM, Lisandro Dalcin wrote:
>> On 2 August 2010 18:21, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>> On Aug 2, 2010, at 9:38 AM, Lisandro Dalcin wrote:
>>>> DAGet[Ghosted]Coordinates return a new reference to the coordinate
>>>> vector. However, this is not the usual pattern of other XXXGetYYY
>>>> calls...
>>>      What do you suggest? (1)  Provide a DARestoreCoordinates() that does the dereference?  (2) remove the reference from the calls (3) change the name from get?
>>>      I like (1) but it is kind of artificial.
>>>   Barry
>> Barry, the DA structure holds references for coordinates,
>> ghosted_coordinates, and da_coordinates, these object are dereferenced
>> at DADestroy():
>> http://petsc.cs.iit.edu/petsc/petsc-dev/file/e89611ec33d6/src/dm/da/src/dadestroy.c#l147
>> So I think that we should just return borrowed references, if needed,
>> they can be manually incref'ed (I would need that in petsc4py). Am I
>> missing something?
>  I don't think you are missing anything.  Take out the references if you like
Done. Let me know immediately in case of problems.
PS: Matt, please update your stuff under src/dm/mesh
Lisandro Dalcin
CIMEC (INTEC/CONICET-UNL)
Predio CONICET-Santa Fe
Colectora RN 168 Km 472, Paraje El Pozo
Tel: +54-342-4511594 (ext 1011)
Tel/Fax: +54-342-4511169
