[petsc-dev] DAGet[Ghosted]Coordinates and refcounts
    Barry Smith
    bsmith at mcs.anl.gov
    Mon Aug  2 16:36:51 CDT 2010
On Aug 2, 2010, at 4:31 PM, Lisandro Dalcin wrote:
> On 2 August 2010 18:21, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> On Aug 2, 2010, at 9:38 AM, Lisandro Dalcin wrote:
>>> DAGet[Ghosted]Coordinates return a new reference to the coordinate
>>> vector. However, this is not the usual pattern of other XXXGetYYY
>>> calls...
>>      What do you suggest? (1)  Provide a DARestoreCoordinates() that does the dereference?  (2) remove the reference from the calls (3) change the name from get?
>>      I like (1) but it is kind of artificial.
>>   Barry
> Barry, the DA structure holds references for coordinates,
> ghosted_coordinates, and da_coordinates, these object are dereferenced
> at DADestroy():
> http://petsc.cs.iit.edu/petsc/petsc-dev/file/e89611ec33d6/src/dm/da/src/dadestroy.c#l147
> So I think that we should just return borrowed references, if needed,
> they can be manually incref'ed (I would need that in petsc4py). Am I
> missing something?
  I don't think you are missing anything.  Take out the references if you like
   Barry
> Lisandro Dalcin
> CIMEC (INTEC/CONICET-UNL)
> Predio CONICET-Santa Fe
> Colectora RN 168 Km 472, Paraje El Pozo
> Tel: +54-342-4511594 (ext 1011)
> Tel/Fax: +54-342-4511169
