TS grand plan
    Matthew Knepley
    knepley at gmail.com
    Tue Sep 22 13:02:21 CDT 2009
On Tue, Sep 22, 2009 at 12:02 PM, Lisandro Dalcin <dalcinl at gmail.com> wrote:
> I commented about this in the past, but let's do it once more...
> Just for reference, in petsc4py (accesible from core PETSc as TSPYTHON
> type when configured --with-petsc4py) more or less uses Jed's model:
> the user routines are in charge of computing F(...)=0 and the
> Jacobian. Moreover, this code can also manage some basic time-step
> control.
> BTW, I proposed something similar to this in the past (look for
> subject "flexible TS implementation for user-defined timestepping").
> Matt (strongly?) resisted the idea, and then I did not continued
> advocating for it
I think my objections were based upon my conviction that methods that need
specific operators or restrictions of operators should have a high level way
of expressing this which incorporates the discretization. Since this seems
far
away (unfortunately), I have stopped opposing the "good enough" stuff.
  Matt
> On Mon, Sep 21, 2009 at 12:01 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> >   Jed,
> >    I suggest you "start from scratch" with "f(t,x,x')" and design what
> makes
> > sense for you and ignore the current Arhs etc.
> > Then we can try to transition the simple ones we have now as you suggest.
> >  Please look at the explicit RK in TS and see how
> > that may fit into your new grand plan.
> >   TS NEVER had a unified plan, which is a big reason why it is no used
> much
> > and is pretty much a POS.
> >   Barry
> > On Sep 20, 2009, at 11:33 PM, Jed Brown wrote:
> >> I'm putting in support for DAEs written in fully implicit form,
> >> i.e. F(t,x,x')=0.  (I brought this up ages ago, but just got to work
> >> implementing it.)  TS uses a frustrating mixed design in an attempt to
> >> reuse code between the different implementations.  Is there clear intent
> >> behind A, B, Alhs, Arhs?  My expectation was that we would be calling
> >> KSPSetOperators(ksp,A,B,...) and SNESSetJacobian(snes,A,B,...) where the
> >> other matrices are for the user, but the usage is much less clear.
> >> TSSetUp:
> >>  KSPSetOperators(ksp,Arhs,B,...)
> >>  SNESSetJacobian(snes,Arhs,B,...)
> >> TS_BEULER:
> >>  A = Arhs; (aliasing)
> >>  KSPSetOperators(ksp,A,A,...)
> >>  SNESSetJacobian(snes,Arhs,B,...)  [shift applied to A=Arhs]
> >>  * -snes_mf_operator doesn't do anything matrix-free, see
> >>   tutorials/ex2 -nox -ts_max_steps 1 -ts_type beuler -snes_mf_operator
> >> -snes_view
> >>   There was a hack to detect MFFD which was introduced in 2004 and
> >>   removed a day later (although the associated comment remains)
> >>  * No support for shifting a preconditioning matrix
> >>   (also made an appearance in 2004)
> >>  * No way to get a different preconditioning matrix to the KSP
> >> TS_CN:
> >>  * linear variable matrix calls ts->ops->rhsmatrix with NULL
> >> preconditioning
> >>  matrix
> >>  * For linear problems with variable matrix, A is destroyed and
> >>  recreated every step
> >>  * For nonlinear problems, only B is shifted
> >> Is there some consistent grand plan?
> >> More trivially, I ripped isExplicit and Iindex out of _p_TS because they
> >> are never used in PETSc.
> >> As a very basic DAE integrator, I wrote an implementation of the theta
> >> method as a 1-step Runge-Kutta which only uses the implicit form
> >> F(t,x,xdot)=0.  With the implicit formulation, the matrices Alhs, Arhs
> >> never appear and instead the user assembles exactly the matrix that is
> >> needed by SNES.  Of course, we can serve up the various explicit
> >> representations (xdot = f(t,x) and the linear cases) with light
> >> wrappers, but I feel like I'm fighting the use of A,B,Alhs,Arhs in
> >> interface/ts.c.
> >> It seems to me that with a little caching, we should be able to make all
> >> the implicit integrators use only the F(t,x,xdot)=0 form and still get
> >> comparable efficiency to the specialized versions that we have now.
> >> Since TS_THETA includes the functionality of TS_BEULER and TS_CN as
> >> special cases, we could remove the latter if we can demonstrate that the
> >> fully implicit formulation doesn't lose efficiency for the RHS and
> >> linear cases (I expect it will be more efficient when the user provides
> >> the implicit form because we get to skip scaling and shifting).
> >> Jed
> Lisandro Dalcín
> Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
> Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
> Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
> PTLC - Güemes 3450, (3000) Santa Fe, Argentina
> Tel/Fax: +54-(0)342-451.1594
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20090922/e49c3969/attachment.html>
