TS grand plan
    Lisandro Dalcin
    dalcinl at gmail.com
    Tue Sep 22 12:02:09 CDT 2009
I commented about this in the past, but let's do it once more...
Just for reference, in petsc4py (accesible from core PETSc as TSPYTHON
type when configured --with-petsc4py) more or less uses Jed's model:
the user routines are in charge of computing F(...)=0 and the
Jacobian. Moreover, this code can also manage some basic time-step
control.
BTW, I proposed something similar to this in the past (look for
subject "flexible TS implementation for user-defined timestepping").
Matt (strongly?) resisted the idea, and then I did not continued
advocating for it
On Mon, Sep 21, 2009 at 12:01 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   Jed,
>    I suggest you "start from scratch" with "f(t,x,x')" and design what makes
> sense for you and ignore the current Arhs etc.
> Then we can try to transition the simple ones we have now as you suggest.
>  Please look at the explicit RK in TS and see how
> that may fit into your new grand plan.
>   TS NEVER had a unified plan, which is a big reason why it is no used much
> and is pretty much a POS.
>   Barry
> On Sep 20, 2009, at 11:33 PM, Jed Brown wrote:
>> I'm putting in support for DAEs written in fully implicit form,
>> i.e. F(t,x,x')=0.  (I brought this up ages ago, but just got to work
>> implementing it.)  TS uses a frustrating mixed design in an attempt to
>> reuse code between the different implementations.  Is there clear intent
>> behind A, B, Alhs, Arhs?  My expectation was that we would be calling
>> KSPSetOperators(ksp,A,B,...) and SNESSetJacobian(snes,A,B,...) where the
>> other matrices are for the user, but the usage is much less clear.
>> TSSetUp:
>>  KSPSetOperators(ksp,Arhs,B,...)
>>  SNESSetJacobian(snes,Arhs,B,...)
>> TS_BEULER:
>>  A = Arhs; (aliasing)
>>  KSPSetOperators(ksp,A,A,...)
>>  SNESSetJacobian(snes,Arhs,B,...)  [shift applied to A=Arhs]
>>  * -snes_mf_operator doesn't do anything matrix-free, see
>>   tutorials/ex2 -nox -ts_max_steps 1 -ts_type beuler -snes_mf_operator
>> -snes_view
>>   There was a hack to detect MFFD which was introduced in 2004 and
>>   removed a day later (although the associated comment remains)
>>  * No support for shifting a preconditioning matrix
>>   (also made an appearance in 2004)
>>  * No way to get a different preconditioning matrix to the KSP
>> TS_CN:
>>  * linear variable matrix calls ts->ops->rhsmatrix with NULL
>> preconditioning
>>  matrix
>>  * For linear problems with variable matrix, A is destroyed and
>>  recreated every step
>>  * For nonlinear problems, only B is shifted
>> Is there some consistent grand plan?
>> More trivially, I ripped isExplicit and Iindex out of _p_TS because they
>> are never used in PETSc.
>> As a very basic DAE integrator, I wrote an implementation of the theta
>> method as a 1-step Runge-Kutta which only uses the implicit form
>> F(t,x,xdot)=0.  With the implicit formulation, the matrices Alhs, Arhs
>> never appear and instead the user assembles exactly the matrix that is
>> needed by SNES.  Of course, we can serve up the various explicit
>> representations (xdot = f(t,x) and the linear cases) with light
>> wrappers, but I feel like I'm fighting the use of A,B,Alhs,Arhs in
>> interface/ts.c.
>> It seems to me that with a little caching, we should be able to make all
>> the implicit integrators use only the F(t,x,xdot)=0 form and still get
>> comparable efficiency to the specialized versions that we have now.
>> Since TS_THETA includes the functionality of TS_BEULER and TS_CN as
>> special cases, we could remove the latter if we can demonstrate that the
>> fully implicit formulation doesn't lose efficiency for the RHS and
>> linear cases (I expect it will be more efficient when the user provides
>> the implicit form because we get to skip scaling and shifting).
>> Jed
Lisandro Dalcín
Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
PTLC - Güemes 3450, (3000) Santa Fe, Argentina
Tel/Fax: +54-(0)342-451.1594
