fixes for MatILUDTFactor_SeqAIJ
Lisandro Dalcin
dalcinl at gmail.com
Tue Sep 15 21:02:38 CDT 2009
On Tue, Sep 15, 2009 at 10:58 PM, Hong Zhang <hzhang at mcs.anl.gov> wrote:
> Lisandro,
> This is an ongoing development.
> Your patch below is fine. Please push to petsc-dev.
> Hong
Oh! Sorry... I completely forgot you were working on this; now I
remember... Anyway, I'll push the patch...
> On Tue, 15 Sep 2009, Lisandro Dalcin wrote:
>> Can someone review the patch below?
>> Perhaps the dt & dtcol initialization should also go to PCCreate_ILU ?
>> $ hg diff
>> diff -r 3af956418390 src/mat/impls/aij/seq/aijfact.c
>> --- a/src/mat/impls/aij/seq/aijfact.c Mon Sep 14 22:53:57 2009 -0500
>> +++ b/src/mat/impls/aij/seq/aijfact.c Tue Sep 15 20:18:12 2009 -0300
>> @@ -2245,18 +2245,22 @@
>> const PetscInt *r,*ic;
>> PetscInt i,n=A->rmap->n,*ai=a->i,*aj=a->j,*ajtmp,*adiag;
>> PetscInt *bi,*bj,*bdiag,*bdiag_rev;
>> - PetscInt row,nzi,nzi_bl,nzi_bu,*im,dtcount,nzi_al,nzi_au;
>> + PetscInt row,nzi,nzi_bl,nzi_bu,*im,nzi_al,nzi_au;
>> PetscInt nlnk,*lnk;
>> PetscBT lnkbt;
>> PetscTruth row_identity,icol_identity,both_identity;
>> MatScalar
>> *aatmp,*pv,*batmp,*ba,*rtmp,*pc,multiplier,*vtmp,diag_tmp;
>> const PetscInt *ics;
>> PetscInt j,nz,*pj,*bjtmp,k,ncut,*jtmp;
>> - PetscReal dt=info->dt,shift=info->shiftinblocks;
>> - PetscInt nnz_max;
>> + PetscReal
>> dt=info->dt,dtcol=info->dtcol,shift=info->shiftinblocks;
>> + PetscInt dtcount=(PetscInt)info->dtcount,nnz_max;
>> PetscTruth missing;
>> PetscFunctionBegin;
>> + if (dt == PETSC_DEFAULT) dt = 0.005;
>> + if (dtcol == PETSC_DEFAULT) dtcol = 0.01; /* XXX unused! */
>> /* ------- symbolic factorization, can be reused ---------*/
>> ierr = MatMissingDiagonal(A,&missing,&i);CHKERRQ(ierr);
>> if (missing) SETERRQ1(PETSC_ERR_ARG_WRONGSTATE,"Matrix is missing
>> diagonal entry %D",i);
>> @@ -2272,10 +2276,10 @@
>> ierr = PetscMalloc((2*n+2)*sizeof(PetscInt),&bi);CHKERRQ(ierr);
>> /* allocate bj and ba; max num of nonzero entries is
>> (ai[n]+2*n*dtcount+2) */
>> - dtcount = (PetscInt)info->dtcount;
>> + if (dtcount == PETSC_DEFAULT) dtcount = (PetscInt)(1.5*a->rmax);
>> if (dtcount > n-1) dtcount = n-1; /* diagonal is excluded */
>> nnz_max = ai[n]+2*n*dtcount+2;
>> ierr = PetscMalloc((nnz_max+1)*sizeof(PetscInt),&bj);CHKERRQ(ierr);
>> ierr = PetscMalloc((nnz_max+1)*sizeof(MatScalar),&ba);CHKERRQ(ierr);
>> Lisandro Dalcín
>> Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
>> Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
>> Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
>> PTLC - Güemes 3450, (3000) Santa Fe, Argentina
>> Tel/Fax: +54-(0)342-451.1594
Lisandro Dalcín
