fixes for MatILUDTFactor_SeqAIJ
    Hong Zhang
    hzhang at mcs.anl.gov
    Tue Sep 15 20:58:26 CDT 2009
Lisandro,
This is an ongoing development.
Your patch below is fine. Please push to petsc-dev.
Hong
On Tue, 15 Sep 2009, Lisandro Dalcin wrote:
> Can someone review the patch below?
> Perhaps the dt & dtcol initialization should also go to PCCreate_ILU ?
> $ hg diff
> diff -r 3af956418390 src/mat/impls/aij/seq/aijfact.c
> --- a/src/mat/impls/aij/seq/aijfact.c	Mon Sep 14 22:53:57 2009 -0500
> +++ b/src/mat/impls/aij/seq/aijfact.c	Tue Sep 15 20:18:12 2009 -0300
> @@ -2245,18 +2245,22 @@
>   const PetscInt     *r,*ic;
>   PetscInt           i,n=A->rmap->n,*ai=a->i,*aj=a->j,*ajtmp,*adiag;
>   PetscInt           *bi,*bj,*bdiag,*bdiag_rev;
> -  PetscInt           row,nzi,nzi_bl,nzi_bu,*im,dtcount,nzi_al,nzi_au;
> +  PetscInt           row,nzi,nzi_bl,nzi_bu,*im,nzi_al,nzi_au;
>   PetscInt           nlnk,*lnk;
>   PetscBT            lnkbt;
>   PetscTruth         row_identity,icol_identity,both_identity;
>   MatScalar          *aatmp,*pv,*batmp,*ba,*rtmp,*pc,multiplier,*vtmp,diag_tmp;
>   const PetscInt     *ics;
>   PetscInt           j,nz,*pj,*bjtmp,k,ncut,*jtmp;
> -  PetscReal          dt=info->dt,shift=info->shiftinblocks;
> -  PetscInt           nnz_max;
> +  PetscReal          dt=info->dt,dtcol=info->dtcol,shift=info->shiftinblocks;
> +  PetscInt           dtcount=(PetscInt)info->dtcount,nnz_max;
>   PetscTruth         missing;
>   PetscFunctionBegin;
> +  if (dt      == PETSC_DEFAULT) dt      = 0.005;
> +  if (dtcol   == PETSC_DEFAULT) dtcol   = 0.01; /* XXX unused! */
>   /* ------- symbolic factorization, can be reused ---------*/
>   ierr = MatMissingDiagonal(A,&missing,&i);CHKERRQ(ierr);
>   if (missing) SETERRQ1(PETSC_ERR_ARG_WRONGSTATE,"Matrix is missing
> diagonal entry %D",i);
> @@ -2272,10 +2276,10 @@
>   ierr = PetscMalloc((2*n+2)*sizeof(PetscInt),&bi);CHKERRQ(ierr);
>   /* allocate bj and ba; max num of nonzero entries is (ai[n]+2*n*dtcount+2) */
> -  dtcount = (PetscInt)info->dtcount;
> +  if (dtcount == PETSC_DEFAULT) dtcount = (PetscInt)(1.5*a->rmax);
>   if (dtcount > n-1) dtcount = n-1; /* diagonal is excluded */
>   nnz_max  = ai[n]+2*n*dtcount+2;
>   ierr = PetscMalloc((nnz_max+1)*sizeof(PetscInt),&bj);CHKERRQ(ierr);
>   ierr = PetscMalloc((nnz_max+1)*sizeof(MatScalar),&ba);CHKERRQ(ierr);
> Lisandro Dalcín
> Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
> Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
> Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
> PTLC - Güemes 3450, (3000) Santa Fe, Argentina
> Tel/Fax: +54-(0)342-451.1594
