Invalid argument!
    Sergio Zlotnik
    techas at gmail.com
    Tue Sep 15 01:50:37 CDT 2009
Hi All,
I need some help with the following error:
[59]PETSC ERROR: --------------------- Error Message
[59]PETSC ERROR: Invalid argument!
[59]PETSC ERROR: Unknown logical value: !
[59]PETSC ERROR:
[59]PETSC ERROR: Petsc Release Version 2.3.3, Patch 8, Fri Nov 16 17:03:40
CST 2007 HG revision: 414581156e67e55c761739b0deb119f7590d0f4b
[59]PETSC ERROR: See docs/changes/index.html for recent updates.
[59]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[59]PETSC ERROR: See docs/index.html for manual pages.
[59]PETSC ERROR:
[59]PETSC ERROR:
/gpfs/home/mona97/mona97824/sz/underworld2/build/bin/StGermain on a
linux-gnu named s25c4b04 by mona97824 Tue Sep 15 07:07:18 2009
[59]PETSC ERROR: Libraries linked from
/gpfs/apps/PETSC/2.3.3-p8/mpi2/64//lib/linux-gnu-c-opt
[59]PETSC ERROR: Configure run at Wed Aug 12 13:29:03 2009
The code does not break after the error!
Any idea of what should I check???
I'm using multigrid with the following options:
-scr_ksp_max_it 300
-scr_ksp_type  bcgs
-scr_ksp_rtol 3.0e-3
-scr_ksp_monitor
-scr_ksp_converged_reason
-Q22_pc_type uwscale
-A11_ksp_rtol 3.0e-4
-A11_ksp_type bcgs
-A11_pc_mg_cycle_type v
-no_scale
-no_remove_nullspace
-A11_pc_mg_log
-A11_pc_mg_multiplicative_cycles 1
-A11_pc_mg_smoothup 1
-A11_pc_mg_smoothdown 1
-pc_mg_different_smoothers
-mg_levels_down_ksp_type cg
-mg_levels_down_pc_type bjacobi
-mg_coarse_ksp_type cg
-mg_coarse_ksp_max_it 100
-mg_coarse_ksp_rtol 3.0e-4
-mg_coarse_pc_type bjacobi
-mg_coarse_sub_pc_type cholesky
-mat_schur_sub_monitor
Thanks in advance,
Sergio
Sergio Zlotnik
Research fellow
School of Geosciences/ School of Mathematical Sciences
Monash University
Clayton campus
Rm 240, Building 28
Monash University VIC 3800
t: (+61 3) 9905 4317
f: (+61 3) 9905 4403
sergio.zlotnik at sci.monash.edu.au
http://users.monash.edu.au/~szlotnik/<http://users.monash.edu.au/%7Eszlotnik/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20090915/7d509bec/attachment.html>
