remove 'x11' test from 'make test'
Boyana Norris norris at mcs.anl.gov
Wed Oct 28 19:01:17 CDT 2009
Apart from the idiot reasons, X11 tests can easily fail on an Apple
laptop because the X server becomes unusable every time the IP
changes, which is fairly frequently. I don't really use X a lot and
thus do not restart the server every time I move the laptop, so these
tests fail almost all the time (but I've learned to ignore those
errors).
Boyana
Boyana Norris, Computer Scientist, Argonne National Laboratory
norris at mcs.anl.gov, +1.630.252.7908, http://www.mcs.anl.gov/~norris/
On Oct 28, 2009, at 6:49 PM, Barry Smith wrote:
> On Oct 28, 2009, at 6:41 PM, Satish Balay wrote:
>> Barry,
>> any objections to removing the 'x11' test from 'make test?'
>> It fails for significant numer of installs [for users without working
>> x11 etc..]. And the c/fortran/parallel tests should be the primary
>> tests anyway..
>  The make rule for make tests only runs this test  when ./configure
> has found X11 and tested that it compiles and links properly.
>  Thus it is not failing because of a failed X11 install.
>   My understanding is that it ONLY fails because people don't have
> the proper DISPLAY variable set. That is either
> 1) DISPLAY does not exist or has garbage or
> 2) DISPLAY points to a proper X server but because of permission
> issues or firewalls the X client cannot connect to the X server.
>   Does it fail for any other reason?
>   I hate to pander to complete idiots who cannot set up their X
> system properly; but I guess you can move that test to a new test
> called
> testx11
>   Barry
>> thanks,
>> Satish
