most efficient way to use local CSR matrix?
Chris Kees christopher.e.kees at usace.army.mil
Tue Oct 20 20:04:55 CDT 2009
Our unstructured finite element code does a fairly standard
overlapping decomposition that allows it to calculate all the non-zero
column entries for the rows owned by the processor (rows 0...ldim-1 in
the local numbering).  We assemble them into a local CSR matrix and
then copy them into a PETSc matrix like this:
for (int i=0;i<ldim;i++)
   irow[0] = i;
   MatSetValuesLocal(PETSCMAT(par_L),1,irow,rowptr[i+1]-
rowptr[i],&colind[rowptr[i]],&a[rowptr[i]],INSERT_VALUES);
where rowptr and colind are the CSR indexing arrays in the local
numbering.
I would like to eliminate the duplicate memory (and the copy above).
Is there a recommended way to let PETSc reference array 'a' directly
or a way to get rid of 'a' and translate our CSR assembly routines to
use low level PETSc data structures?
So far I've added MatMPIAIJSetPreallocationCSR to try to speed up the
first solve, but the documentation is clear that 'a' is not a pointer
to the AIJ storage so I still need the copy. I tried using
MatCreateMPIAIJWithSplitArrays with the 'o' arrays set to zero but I
got indexing errors, and the documentation really seems to imply that
the local matrix is really not a standard CSR anyway. If that's true
then it seems like the options I have are to write a shell matrix for
parallel CSR storage or write some new assembly routines that use
MatSetValuesLocal. I'm more concerned about the memory than the
overhead of MatSetValuesLocal, but it would certainly be easier on me
to use the CSR-based assembly routines we already have.
Chris
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20091020/8e825b38/attachment.html>
