Subsecond sleep
Jed Brown
jed at 59A2.org
Sun Oct 18 16:50:37 CDT 2009
Barry Smith wrote:
> Likely, it had sleep() in there and a global search and replace wrongly
> turned it into a PetscSleep().
My docs for sleep(3) have:
RETURN VALUE
Zero if the requested time has elapsed, or the number of seconds left to sleep, if the call was interrupted by a signal handler.
Presumably the AIX issue was that sleep() was returning without being
interrupted. What are the desired semantics for PetscSleep(), I expect
it should return early if interrupted, like POSIX sleep()? If sleep()
returns early even when not interrupted then I don't see a way for
PetscSleep() to return early if it is interrupted but to go for the full
time otherwise.
> The correct fix is to test properly under AIX, but since no one has AIX
> and it sucks it cannot be tested.
Excellent quote.
Jed
Desc: OpenPGP digital signature
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20091018/f03da2fc/attachment.sig>
