building PETSc on Windows
    Matthew Knepley
    knepley at gmail.com
    Mon Mar 23 11:02:44 CDT 2009
On Mon, Mar 23, 2009 at 11:00 AM, Lisandro Dalcin <dalcinl at gmail.com> wrote:
> On Mon, Mar 23, 2009 at 10:57 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> > The main issue is - win32fe works with cygwin PATHs - not windows paths..
> Sorry, I'm do not know what are you talking about ... Is win32fe a
> compiler wrapper? Note I want to support the stock Python for win +
> MinGW (outside cygwin) + MSYS (minimal system)...
The issue here is supporting the Windows compilers. What you propose would
probably work for gcc, but we use win32fe in order to support all the
compilers
made the MS programming environment.
  Matt
> > Satish
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20090323/af35e5cf/attachment.html>
