building PETSc on Windows
    Lisandro Dalcin
    dalcinl at gmail.com
    Mon Mar 23 11:00:53 CDT 2009
On Mon, Mar 23, 2009 at 10:57 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> The main issue is - win32fe works with cygwin PATHs - not windows paths..
Sorry, I'm do not know what are you talking about ... Is win32fe a
compiler wrapper? Note I want to support the stock Python for win +
MinGW (outside cygwin) + MSYS (minimal system)...
> Satish
> On Mon, 23 Mar 2009, Lisandro Dalcin wrote:
>> The Cygwin way works, but let me say that it is a bit of pain... as a
>> novice in this crapy environment, I've spent a lot of time just to get
>> all the Cygwin stuff properly installed...
>> I'm exploring the possibility of using an alternative, that is, using
>> stock Python for Windows + MinGW + MSYS. MSYS provides a minimal
>> UNIX-like shell and bundles development utilities like make. IMHO, it
>> is a much lighter approach to Cygwin... I believe the alternative is
>> possible... However, I have some issues that have to be addressed, and
>> I would need your help...
>> 1) As I'm using the stock Python for Windows, the "select" module does
>> not work on pipes.. Then the machinery for executing things in the
>> shell and get stdout and stderr stuff needs to be reeimplemented... Do
>> not worry about this, I can take this.
>> 2) BuildSystem assumes that the shell is '/bin/sh'... I would need it
>> to find "sh" in the $PATH instead...
>> 3) When checking for make, BuildSystem uses 'strings' somewhere..
>> Again, I need strings to be searched in $PATH.
>> Can any of you try to fix (2) and (3) ? Anyway, that would be a good
>> change even for Unix-like systems, right?
Lisandro Dalcín
Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
PTLC - Güemes 3450, (3000) Santa Fe, Argentina
Tel/Fax: +54-(0)342-451.1594
