script to query PETSc makefile variables?
Boyana Norris norris at mcs.anl.gov
Thu Jan 22 18:06:01 CST 2009
Matthew Knepley wrote:
> On Thu, Jan 22, 2009 at 5:31 PM, Boyana Norris <norris at mcs.anl.gov> wrote:
>> Ah, ok, that explains it -- it's not in the installed version (the one after
>> make install). Should it be? I really would like to avoid depending on the
>> PETSc source directories.
> Technically,
>   1) BuildSystem is a separate project. It has its own repository
And a nice one it is. Can it be installed in its own prefix? Sorry, I
never have, so I don't know the proper incantations -- I don't see a
setup.py, but I haven't investigated further.
>   2) script is superfluous for getting the variables
Yes, we could all write in assembly, too. Not to be too whiny, but
expecting everyone to do interesting things with sed in their makefiles
as a matter of course is not very reasonable. Some users don't even know
how to write a makefile. And very few know how to extract a few values
from a file from within a makefile without relying on an external
script. I do, but I'm thinking about others who'd have to do similar
things in the future (e.g., have a pile of code in which petsc is one of
many external dependencies).
Boyana
>    Matt
>> Boyana
>>> On Thu, Jan 22, 2009 at 5:15 PM, Boyana Norris <norris at mcs.anl.gov> wrote:
>>>> Thank you both -- I'd prefer to use configVars.py, but it seems to depend
>>>> on
>>>> the script module, which is not standard in at least Python 2.5. Googling
>>>> for "python script module" is a joke, as you can imagine. Is this a PETSc
>>>> thing or a general module I can get somewhere?
>>> That module is in PETSc,
>>>  $PETSC_DIR/config/BuildSystem
>>>    Matt
>>>> Thanks!
>>>> Boyana
>>>>> Check out $PETSC_DIR/bin/configVars.py
>>>>>  Matt
>>>>> On Thu, Jan 22, 2009 at 4:38 PM, Satish Balay <balay at mcs.anl.gov> wrote:
>>>>>> On Thu, 22 Jan 2009, Boyana Norris wrote:
>>>>>>> Is there a script that can be used to query the values of various
>>>>>>> variables
>>>>>>> defined in petscvariables makefile snippets (similar to lots of linux
>>>>>>> tools'
>>>>>>> pkg-config scripts)?
>>>>>> [don't have canned code for this but] I've previously recommended
>>>>>> doing the following in the packages configure.. [facets now has this
>>>>>> in their configure to detect petsc]
>>>>>> - petsc_arch and petsc_dir are inputs to configure
>>>>>> - Create a dummy makefile on the fly
>>>>>> - run this makefile to echo relavent stuff..
>>>>>> For eg:
>>>>>> asterix:/home/balay/download-pine>cat configpetsc.sh
>>>>>> #!/bin/sh
>>>>>> PETSC_ARCH=asterix64
>>>>>> PETSC_DIR=/home/balay/spetsc
>>>>>> cat <<EOF > petscmake
>>>>>> PETSC_ARCH = ${PETSC_ARCH}
>>>>>> PETSC_DIR  = ${PETSC_DIR}
>>>>>> include ${PETSC_DIR}/conf/base
>>>>>> EOF
>>>>>> PETSC_INC=`make -f petscmake getincludedirs`
>>>>>> PETSC_LIB=`make -f petscmake getlinklibs`
>>>>>> echo '**** PETSC_INC ***'
>>>>>> echo ${PETSC_INC}
>>>>>> echo '**** PETSC_LIB ***'
>>>>>> echo ${PETSC_LIB}
>>>>>> Satish
>>>> Boyana Norris, Computer Scientist    |   Email: norris at mcs.anl.gov
>>>> Argonne National Laboratory          |   Phone: +1 (630) 252 7908
>>>> http://www.mcs.anl.gov/~norris/      |   Fax:   +1 (630) 252 5986
