script to query PETSc makefile variables?
Matthew Knepley
knepley at gmail.com
Thu Jan 22 17:46:50 CST 2009
On Thu, Jan 22, 2009 at 5:31 PM, Boyana Norris <norris at mcs.anl.gov> wrote:
> Ah, ok, that explains it -- it's not in the installed version (the one after
> make install). Should it be? I really would like to avoid depending on the
> PETSc source directories.
Technically,
1) BuildSystem is a separate project. It has its own repository
2) script is superfluous for getting the variables
Matt
> Boyana
> Matthew Knepley wrote:
>> On Thu, Jan 22, 2009 at 5:15 PM, Boyana Norris <norris at mcs.anl.gov> wrote:
>>> Thank you both -- I'd prefer to use configVars.py, but it seems to depend
>>> on
>>> the script module, which is not standard in at least Python 2.5. Googling
>>> for "python script module" is a joke, as you can imagine. Is this a PETSc
>>> thing or a general module I can get somewhere?
>> That module is in PETSc,
>> $PETSC_DIR/config/BuildSystem
>> Matt
>>> Thanks!
>>> Boyana
>>>> Check out $PETSC_DIR/bin/configVars.py
>>>> Matt
>>>> On Thu, Jan 22, 2009 at 4:38 PM, Satish Balay <balay at mcs.anl.gov> wrote:
>>>>> On Thu, 22 Jan 2009, Boyana Norris wrote:
>>>>>> Is there a script that can be used to query the values of various
>>>>>> variables
>>>>>> defined in petscvariables makefile snippets (similar to lots of linux
>>>>>> tools'
>>>>>> pkg-config scripts)?
>>>>> [don't have canned code for this but] I've previously recommended
>>>>> doing the following in the packages configure.. [facets now has this
>>>>> in their configure to detect petsc]
>>>>> - petsc_arch and petsc_dir are inputs to configure
>>>>> - Create a dummy makefile on the fly
>>>>> - run this makefile to echo relavent stuff..
>>>>> For eg:
>>>>> asterix:/home/balay/download-pine>cat configpetsc.sh
>>>>> #!/bin/sh
>>>>> PETSC_ARCH=asterix64
>>>>> PETSC_DIR=/home/balay/spetsc
>>>>> cat <<EOF > petscmake
>>>>> PETSC_ARCH = ${PETSC_ARCH}
>>>>> PETSC_DIR = ${PETSC_DIR}
>>>>> include ${PETSC_DIR}/conf/base
>>>>> EOF
>>>>> PETSC_INC=`make -f petscmake getincludedirs`
>>>>> PETSC_LIB=`make -f petscmake getlinklibs`
>>>>> echo '**** PETSC_INC ***'
>>>>> echo ${PETSC_INC}
>>>>> echo '**** PETSC_LIB ***'
>>>>> echo ${PETSC_LIB}
>>>>> Satish
>>> Boyana Norris, Computer Scientist | Email: norris at mcs.anl.gov
>>> Argonne National Laboratory | Phone: +1 (630) 252 7908
>>> http://www.mcs.anl.gov/~norris/ | Fax: +1 (630) 252 5986
experiments is infinitely more interesting than any results to which
their experiments lead.
-- Norbert Wiener
