[petsc-dev] Did someone fucking break bfort?
Mon Dec 21 16:42:55 CST 2009
This does not make any sense to me because it would be a heap violation, not
a stack smash.
  Matt
On Mon, Dec 21, 2009 at 4:30 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> [I don't know the correct fix for this - but ] The following change is
> getting rid of valgrind messages for me. Maybe you can use this, build
> sowing separately - and continue..
> Satish
> diff -r dbe25084c0e4 src/bfort/bfort.c
> --- a/src/bfort/bfort.c Mon Dec 15 22:20:58 2008 -0600
> +++ b/src/bfort/bfort.c Mon Dec 21 16:29:09 2009 -0600
> @@ -2157,7 +2157,7 @@
>     /* Current token is name */
>     arg->has_star = (nstar > 0);
> -    arg->name     = (char *)MALLOC( strlen(p) + 1 );
> +    arg->name     = (char *)MALLOC( strlen(p) + 10 );
>     strcpy( arg->name, p );
>     /* We can't output the name just yet, because if it is
> On Mon, 21 Dec 2009, Matthew Knepley wrote:
> > The problem appears to be in OutputRoutine() in bfort.c, but that code is
> > impossible
> > to debug. I can't see where something is getting overwritten, and it
> looks
> > like the check
> > only happens when the routine returns. bfort is such crap.
> >   Matt
> > On Mon, Dec 21, 2009 at 3:25 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
> > > On Mon, Dec 21, 2009 at 3:21 PM, Satish Balay <balay at mcs.anl.gov>
> wrote:
> > >> On Mon, 21 Dec 2009, Lisandro Dalcín wrote:
> > >> > On Mon, Dec 21, 2009 at 5:37 PM, Matthew Knepley <knepley at gmail.com
> > >> wrote:
> > >> > > It says there is a stack smash and no other info. This is
> completely
> > >> fucking
> > >> > > my development right now.
> > >> > Any chance bfort was built with -fstack-protector flag? This failure
> > >> > could could be signaling an actual old bug in bfort... I would
> > >> > re-build bfort with debug and re-run under valgrind...
> > >> That must be it.
> > >> I just ran my build [which is without -fstack-protector] - and
> > >> valgrind does flag a bunch of things with bfort.
> > > 1) That flag is nowhere in my build.
> > > 2) Something changed
> > >   Matt
> > >> I normally install sowing separately and have it in my PATH - so that
> > >> it doesn't have to be rebuilt each time I build petsc.
> > >> I guess we should sync up [our patches] with latest sowing and make
> > >> sure its valgrind clean aswell.
> > >> Satish
> > > What most experimenters take for granted before they begin their
> > > experiments is infinitely more interesting than any results to which
> their
> > > experiments lead.
> > > -- Norbert Wiener
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20091221/b26302e4/attachment.html>
