[petsc-dev] Did someone fucking break bfort?
Mon Dec 21 16:30:34 CST 2009
[I don't know the correct fix for this - but ] The following change is
getting rid of valgrind messages for me. Maybe you can use this, build
sowing separately - and continue..
Satish
diff -r dbe25084c0e4 src/bfort/bfort.c
--- a/src/bfort/bfort.c	Mon Dec 15 22:20:58 2008 -0600
+++ b/src/bfort/bfort.c	Mon Dec 21 16:29:09 2009 -0600
@@ -2157,7 +2157,7 @@
     /* Current token is name */
     arg->has_star = (nstar > 0);
-    arg->name     = (char *)MALLOC( strlen(p) + 1 );
+    arg->name     = (char *)MALLOC( strlen(p) + 10 );
     strcpy( arg->name, p );
     /* We can't output the name just yet, because if it is
On Mon, 21 Dec 2009, Matthew Knepley wrote:
> The problem appears to be in OutputRoutine() in bfort.c, but that code is
> impossible
> to debug. I can't see where something is getting overwritten, and it looks
> like the check
> only happens when the routine returns. bfort is such crap.
>   Matt
> On Mon, Dec 21, 2009 at 3:25 PM, Matthew Knepley <knepley at gmail.com> wrote:
> > On Mon, Dec 21, 2009 at 3:21 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> >> On Mon, 21 Dec 2009, Lisandro Dalcín wrote:
> >> > On Mon, Dec 21, 2009 at 5:37 PM, Matthew Knepley <knepley at gmail.com>
> >> wrote:
> >> > > It says there is a stack smash and no other info. This is completely
> >> fucking
> >> > > my development right now.
> >> > Any chance bfort was built with -fstack-protector flag? This failure
> >> > could could be signaling an actual old bug in bfort... I would
> >> > re-build bfort with debug and re-run under valgrind...
> >> That must be it.
> >> I just ran my build [which is without -fstack-protector] - and
> >> valgrind does flag a bunch of things with bfort.
> > 1) That flag is nowhere in my build.
> > 2) Something changed
> >   Matt
> >> I normally install sowing separately and have it in my PATH - so that
> >> it doesn't have to be rebuilt each time I build petsc.
> >> I guess we should sync up [our patches] with latest sowing and make
> >> sure its valgrind clean aswell.
> >> Satish
> > What most experimenters take for granted before they begin their
> > experiments is infinitely more interesting than any results to which their
> > experiments lead.
> > -- Norbert Wiener
