Putting a peculiar multilevel scheme into DMMG?
Jed Brown
jed at 59A2.org
Mon Dec 14 00:29:59 CST 2009
On Sun, 13 Dec 2009 18:56:46 -0600, Matthew Knepley <knepley at gmail.com> wrote:
> > DM *tmp;
> > DMRefineHierarchy(dmc,1,&tmp);
> > dmf = *tmp;
> > PetscFree(tmp);
> I am not sure why this is much worse. There are many things users are
> required to destroy.
You must agree that it's clunky considering that the alternative would
be
DMRefineHierarchy(dmc,1,&dmf);
Callee-allocates is especially awkward when DMRefineHierarchy is being
used in the implementation of DMRefineHierarchy (e.g. in my case where
part of the hierarchy is conventional while another part is custom).
Besides, most things that the user has to free come with a dedicated API
to free them (usually XRestoreY) which doesn't make sense here.
And the current callee-allocates was not actually correct: mesh.c:1865
creates more new meshes than it should and the last one is never
populated (Hierarchy.hh:1179) so something nontrivial was leaking.
I don't particularly care, but I think caller-allocates amounts to less
code (when averaged over the common cases) and more obvious semantics.
Jed
