stupid, stupid, stupid MPI.py
Barry Smith
bsmith at mcs.anl.gov
Sun Dec 13 21:36:15 CST 2009
So if I pass --with-mpi-shared into MPI.py it TESTS if the MPI
libraries are shared. Fine. But if it is download-mpich IT DOES NOT
try to make shared libraries for MPICH. It only tries to make shared
libraries for MPI if --with-shared is passed. WTF?
So I change it so that it tries to make mpi shared libraries if --
with-mpi-shared is passed but not also --with-shared. What happens?
"Configuring with shared libraries - but the system/compilers do not
support this." How the hell does it know the system/compilers do not
support this? So I have to change the code to not reject the --with-
mpi-shared when using static libraries.
Sometimes I just want to delete the whole stinking repository of
crud piled on crap piled on crud. Maybe we need to start having code
reviews instead of shoving random code into random files and hope that
sometimes things might work.
Ok, well I shoved some random code in and got it to behave
reasonably for me, until tomorrow,
Barry
This problem caused my early problem, since it ignored the --with-mpi-
shared option it did not think it needed to rebuild mpich.
