[francois pacull] Re: fieldsplits
    Jed Brown
    jed at 59A2.org
    Thu Dec 10 15:32:22 CST 2009
On Thu, 10 Dec 2009 15:12:38 -0600, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Dec 10, 2009, at 3:03 PM, Jed Brown wrote:
> > Can KSPView before KSPSolve reasonably be made to work?
>     In general KSPView() should work perfect after KSPSetUp() but
> before KSPSolve() BUT with the heirarchical preconditioners (like even
> block Jacobi) some inner KSPSetUps() may not happen before the
> KSPSolve() hence the view may not work correctly.
> There is a KSPSetUpOnBlocks() that is suppose to make sure the inner
> KSPSetUp()s are called, but with many-level heirarchical
> preconditioners it may not get all the inner setups done properly.
>    I do not know if it is possible to get it all correct in all cases
> of composing preconditioners. I think  it is difficult.
I think so too, he said it "crashed", and I could produce SIGSEGV by
putting DMMGView before DMMGSolve in multiphysics/mp.c
(MatSchurComplementGetKSP called with A=0).  I just pushed a patch to
prevent fieldsplit from attempting to view inner objects before they
exist (just say "not yet available").
Jed
