since developing object oriented software is so cumbersome in C and we are all resistent to doing it in C++
Ethan Coon
etc2103 at columbia.edu
Sat Dec 5 15:17:38 CST 2009
> This is a very interesting issue. Suppose you write the RHSFunction in
> Python
> and pass to SNES. Are you saying that pdb cannot stop in that method
> when
> you step over SNESSolve() in Python? That would suck. If on the other
> hand,
> you passed in C, I can see how you are relegated to obscure gdb. This
> happens
> to me in PyLith.
No, I believe pure Python works fine. Cython does wierd things however.
Haven't tried pure C. If you have a way of getting gdb to step between
the python parts, the petsc parts, and the passed-in functions in
C/Cython, I'd love to hear it (offlist would probably be better).
Ethan
> Matt
> I'm all in favor of a hybrid model, but the debugging
> support/issues
> would need to be addressed.
> Ethan
> On Sat, 2009-12-05 at 12:03 -0800, Brad Aagaard wrote:
> > As someone who has a finite-element code built upon
> PETSc/Sieve with the
> > top-level code in Python, I am in favor of Barry's approach.
> > As Matt mentions debugging multi-languages is more complex.
> Unit testing
> > helps solve some of this because tests associated with the
> low-level
> > code involve only one language and find most of the bugs.
> > We started with manual C++/Python interfaces, then moved to
> Pyrex, and
> > now use SWIG. Because we use C++, the OO support in SWIG
> results in a
> > much better simpler, cleaner interface between Python and C
> ++ than what
> > is possible with Pyrex or Cython. SWIG has eliminated 95% of
> the effort
> > to interface Python and C++ compared to Pyrex.
> > Brad
> > Matthew Knepley wrote:
> > > On Fri, Dec 4, 2009 at 10:42 PM, Barry Smith
> <bsmith at mcs.anl.gov
> > > <mailto:bsmith at mcs.anl.gov>> wrote:
> > > Suggestion:
> > > 1) Discard PETSc
> > > 2) Develop a general Py{CL, CUDA, OpenMP-C} system
> that dispatches
> > > "tasks" onto GPUs and multi-core systems (generally we
> would have
> > > one python process per compute node and local
> parallelism would be
> > > done via the low-level kernels to the cores and/or
> GPUs.)
> > > 3) Write a new PETSc using MPI4py and 2) written
> purely in Python
> > > 3000 using all its cool class etc features
> > > 4) Use other packages (like f2py) to generate bindings
> so that 3)
> > > maybe called from Fortran90/2003 and C++ (these
> probably suck since
> > > people usually think the other way around; calling
> Fortran/C++ from
> > > Python, but maybe we shouldn't care; we and our
> friends can just be
> > > 10 times more efficient developing apps in Python).
> > > enjoy coding much better than today.
> > > What is wrong with Python 3000 that would make this
> approach not be
> > > great?
> > > I am very a big fan of this approach. Let me restate it:
> > > a) Write the initial code in Python for correctness
> checking, however
> > > develop a performance model which will allow transition to
> an accelerator
> > > b) Move key pieces to a faster platform using
> > > i) Cython
> > > ii) PyCUDA
> > > c) Coordinate loose collection of processes with MPI for
> large problems
> > > A few comments. Notice that for many people c) is
> unnecessary if you can
> > > coordinate several GPUs from one CPU. The
> > > key piece here is a dispatch system. Felipe, Rio, and I
> are getting this
> > > done now. Second, we can leverage all of petc4py
> > > in step b.
> > > In my past attempts at this development model, they have
> always
> > > floundered on inner loops or iterations. These cannot be
> > > done in Python (too slow) and cannot be wrapped (too much
> overhead).
> > > However, now we have a way to do this, namely
> > > RunTime Code Generation (like PyCUDA). I think this will
> get us over the
> > > hump, but we have to rethink how we code things,
> > > especially traversals, which now become lists of scheduled
> tasks as in
> > > FLASH (from van de Geijn).
> > > Matt
> > > Barry
> > > When coding a new numerical algorithm for PETSc we
> would just code
> > > in Python, then when tested and happy with reimplement
> in Py{{CL,
> > > CUDA, OpenMP-C}
> > > The other choice is designing and implementing our own
> cool/great OO
> > > language with the flexibilty and power we want, but I
> fear that is
> > > way to hard and why not instead leverage Python.
> > > What most experimenters take for granted before they begin
> their
> > > experiments is infinitely more interesting than any
> results to which
> > > their experiments lead.
> > > -- Norbert Wiener
> Ethan Coon
> DOE CSGF - Graduate Student
> Dept. Applied Physics & Applied Mathematics
> Columbia University
> 212-854-0415
> http://www.ldeo.columbia.edu/~ecoon/
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
Ethan Coon
Columbia University
212-854-0415
