since developing object oriented software is so cumbersome in C and we are all resistent to doing it in C++
Matthew Knepley
knepley at gmail.com
Sat Dec 5 14:31:54 CST 2009
On Sat, Dec 5, 2009 at 2:29 PM, Ethan Coon <etc2103 at columbia.edu> wrote:
> I'm a big fan of Barry's approach as well.
> However, the current state of debugging tools is not up to snuff for
> this type of model. In using petsc4py regularly, debugging cython and
> python ("user-defined") functions after they've been passed into PETSc
> just plain sucks -- it basically means reverting to print statements.
> And while unit testing can help for a lot of it, expecting users to
> write unit tests for even the most basic of their physics functions is a
> little unreasonable. Even basic exception propagation would be a huge
> step forward.
This is a very interesting issue. Suppose you write the RHSFunction in
Python
and pass to SNES. Are you saying that pdb cannot stop in that method when
you step over SNESSolve() in Python? That would suck. If on the other hand,
you passed in C, I can see how you are relegated to obscure gdb. This
happens
to me in PyLith.
Matt
> I'm all in favor of a hybrid model, but the debugging support/issues
> would need to be addressed.
> Ethan
> On Sat, 2009-12-05 at 12:03 -0800, Brad Aagaard wrote:
> > As someone who has a finite-element code built upon PETSc/Sieve with the
> > top-level code in Python, I am in favor of Barry's approach.
> > As Matt mentions debugging multi-languages is more complex. Unit testing
> > helps solve some of this because tests associated with the low-level
> > code involve only one language and find most of the bugs.
> > We started with manual C++/Python interfaces, then moved to Pyrex, and
> > now use SWIG. Because we use C++, the OO support in SWIG results in a
> > much better simpler, cleaner interface between Python and C++ than what
> > is possible with Pyrex or Cython. SWIG has eliminated 95% of the effort
> > to interface Python and C++ compared to Pyrex.
> > Brad
> > Matthew Knepley wrote:
> > > On Fri, Dec 4, 2009 at 10:42 PM, Barry Smith <bsmith at mcs.anl.gov
> > > <mailto:bsmith at mcs.anl.gov>> wrote:
> > > Suggestion:
> > > 1) Discard PETSc
> > > 2) Develop a general Py{CL, CUDA, OpenMP-C} system that dispatches
> > > "tasks" onto GPUs and multi-core systems (generally we would have
> > > one python process per compute node and local parallelism would be
> > > done via the low-level kernels to the cores and/or GPUs.)
> > > 3) Write a new PETSc using MPI4py and 2) written purely in Python
> > > 3000 using all its cool class etc features
> > > 4) Use other packages (like f2py) to generate bindings so that 3)
> > > maybe called from Fortran90/2003 and C++ (these probably suck since
> > > people usually think the other way around; calling Fortran/C++ from
> > > Python, but maybe we shouldn't care; we and our friends can just be
> > > 10 times more efficient developing apps in Python).
> > > enjoy coding much better than today.
> > > What is wrong with Python 3000 that would make this approach not
> be
> > > great?
> > > I am very a big fan of this approach. Let me restate it:
> > > a) Write the initial code in Python for correctness checking, however
> > > develop a performance model which will allow transition to an
> accelerator
> > > b) Move key pieces to a faster platform using
> > > i) Cython
> > > ii) PyCUDA
> > > c) Coordinate loose collection of processes with MPI for large
> problems
> > > A few comments. Notice that for many people c) is unnecessary if you
> can
> > > coordinate several GPUs from one CPU. The
> > > key piece here is a dispatch system. Felipe, Rio, and I are getting
> this
> > > done now. Second, we can leverage all of petc4py
> > > in step b.
> > > In my past attempts at this development model, they have always
> > > floundered on inner loops or iterations. These cannot be
> > > done in Python (too slow) and cannot be wrapped (too much overhead).
> > > However, now we have a way to do this, namely
> > > RunTime Code Generation (like PyCUDA). I think this will get us over
> the
> > > hump, but we have to rethink how we code things,
> > > especially traversals, which now become lists of scheduled tasks as in
> > > FLASH (from van de Geijn).
> > > Matt
> > > Barry
> > > When coding a new numerical algorithm for PETSc we would just code
> > > in Python, then when tested and happy with reimplement in Py{{CL,
> > > CUDA, OpenMP-C}
> > > The other choice is designing and implementing our own cool/great
> OO
> > > language with the flexibilty and power we want, but I fear that is
> > > way to hard and why not instead leverage Python.
> > > What most experimenters take for granted before they begin their
> > > experiments is infinitely more interesting than any results to which
> > > their experiments lead.
> > > -- Norbert Wiener
> Ethan Coon
> DOE CSGF - Graduate Student
> Dept. Applied Physics & Applied Mathematics
> Columbia University
> 212-854-0415
> http://www.ldeo.columbia.edu/~ecoon/<http://www.ldeo.columbia.edu/%7Eecoon/>
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20091205/67786fec/attachment.html>
