possible new problem: dynlibs retrieved twice, need advice for fix
Barry Smith
bsmith at mcs.anl.gov
Tue Oct 21 20:51:00 CDT 2008
On Oct 21, 2008, at 6:37 PM, Lisandro Dalcin wrote:
> Barry, your arguments were really convincing. So I would propose the
> following API changes:
> 1) Private Interface:
> 1.a) PetscDLLibraryRetrieve(comm, path, ... ):
> Implements automatic file retrieval.
> 1.b) PetscDLLibraryOpen(comm, path, flags, &entry):
> - call 1.a for file retrieval
> - next dlopen()/LoadLibrary() (flags are for dlopen)
> - and finally malloc and fill a new PetscDLLibrary entry.
> 1.c) PetscDLLibraryClose(comm, &entry):
> - first dlclose()/FreeLibrary()
> - and then free then PetscDLLibrary entry allocated in 1.b
> *change: this is the oposite to 1.b
> 1) Public Interface
> 2.a) PetscDLLibrary:
> a list of loaded dynlibs
> 2.b) PetscDLLibrary{Append|Prepend}(comm, list, path, flags)
> automatic file retrieval + dlopen()/LoadLibrary() +
> append/prepend in list
> * change: add arg for dlopen() flags RTLD_{LAZY|NOW}/
> {LOCAL_GLOBAL}
I don't understand these flags, if you need to open in different
modes for different uses
I guess it is ok to add them (they would be a new PetscEnum)
> 2.c) PetscDLLibrarySym(comm, list, symbol, &value):
> look for symbol in list (and also program code if not found in
> list)
> *change: path removed, use 1.b for adding new libs to the list.
Do you mean 2.b? That is, the
user has to add the library to list before
calling this? (More like conventional dlsym().?)
If so, this is fine with me.
> 2.d) PetscDLLibraryClear(comm, &list):
> free list entries calling 1.c, and finally set list to NULL.
> *change 1: former name was PetscDLLibraryClose
> *change 2: trully call dlclose()/FreeLibrary() on handles.
> Some additional notes:
> - In some cases, the comm argument is unused, but let it there just in
> case we need it in the near future.
> - As I know you hate abreviations, perhaps we could rename
> PetscDLLibrarySym to PetscDLLibraryLookSymbol ?
> That's all :-) . What do you think? Feel free to suggest better names
> for the routines, you are far better than me for that.
I see the value in making the model match the dlopen(), dlsym(),
dlclose() model as is reasonable,
so here goes
Replace the PetscDLLibraryAppend/Prepend() with a single
PetscDLOpen(). Make
the current PetscDLLibraryOpen() become PetscDLLibraryOpen_Private()
and your proposed
PetscDLLibraryClose() with PetscDLLibraryClose_Private(). Keep the
current PetscDLLibraryClose()
but have it call the private one for each entry.
Finally throw the Library out of the names.
Since you want to redo it then we should do it right and use the
PETSc paradigm. (so ignore my suggestions above).
PetscDL dl; /* could make dl Opaque like Mat, Vec, etc but not
neccessary
PetscDLOpen(MPI_Comm comm,PetscDL *dl);
PetscDLAdd(PetscDL dl, flags you want "filename");
PetscDLAdd(.....)
PetscDLSym(PetscDL dl, ....
PetscDLSym(.....
PetscDLDestroy(PetscDL dl);
All utilities used by this would have _Private() in their name.
Make sense, am I missing something?
Barry
You better check that
> On Tue, Oct 21, 2008 at 3:59 PM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
>> Lisandro,
>> I've briefly reviewed the code to refresh my memory on how it
>> work. Here
>> is
>> my interpretation of the present structure.
>> Public interface
>> PetscDLLibraryAppend() and Prepend()
>> PetscDLLibrarySym()
>> "Private" interface
>> PetscDLLibraryOpen() (note that this is not really the
>> opposite of
>> PetscDLLibraryRetrieve()
>> These are intended as THE replacement to dlopen(), dlsym(),
>> dlclose(). Hence
>> having
>> a PetscDLOpen(), PetscDLSym(), PetscDLClose() would be redundant.
>> You know I
>> hate
>> to have two different ways to do the same thing.
>> _n_PetscDLLibrary is then a REPLACEMENT for the void** handle you
>> get from
>> dlopen(),
>> but it has the additional functionality that several handles can be
>> kept and
>> used together.
>> PetscDLLibraryAppend() and Prepend() are then THE replacement for
>> dlopen()
>> and
>> PetscDLLibrarySym() is THE replacement for dlsym().
>> PetscDLLibrarySym() is a replacement for dlsym() with the
>> flexibility to
>> find a symbol is
>> several handles/files and to look in a particular file for the
>> symbol. The
>> idea is Unix paths,
>> when I run cc it looks for cc in that path and when I run /bin/cc I
>> tell it
>> which particular one
>> to use.
>> The ALL have the IMPORTANT dependence on a MPI_Comm, that
>> dlopen(),... do
>> not.
>> This is all independent of whether one is using PETSc dynamic
>> libraries or
>> not , except I
>> have the single PETSC_HAVE_DYNAMIC flag that turns everything on.
>> The entire
>> dl.c
>> file should be TURNED on if the PETSC_HAVE_DYNAMIC flag is on.
>> Traditional dlopen(), dlsym() dlclose() can be emulated with the
>> above using
>> PetscDLLibrary *library = PETSC_NULL
>> PetscDLLibraryAppend(.... &library,filename)
>> PetscDLLibrarySym(....library, symbolname)
>> PetscDLLibrarySym on other symbols
>> PetscDLLibraryClose(library)
>> Now for PETSc's dynamic libraries, PETSc maintains A
>> _n_PetscDLLibrary
>> object for managing ITS dynamic libraries.
>> this is handled through the PetscLoadDynamicLibrary() interface.
>> This
>> interface should
>> be turned on ONLY if PETSC_USE_DYNAMIC libraries is turned on.
>> My question to you is then: what changes/additions/fixes do we need
>> to add
>> to the
>> PetscDLLibraryAppend() and Prepend() PetscDLLibrarySym()
>> public interface so that it may be used for all of your needs????
>> Ok, the
>> current interface
>> may be a little clumsy, let's make it less clumsy rather than
>> adding a whole
>> new PetscDLOpen()...
>> interface next to it that has the same functionality. I'm even fine
>> with
>> changing names and adding
>> new methods to the current interface.
>> Barry
>> On Oct 21, 2008, at 10:04 AM, Lisandro Dalcin wrote:
>>> Barry, I catched a new problem. At PetscInitialize(), dynamic
>>> libraries are 'retrieved' twice. The calls that leads to this are
>>> the
>>> following:
>>> PetscInitialize()
>>> PetscInitialize_DynamicLibraries()
>>> PetscLoadDynamicLibrary() // helper routine for opening each
>>> libpescXXX
>>> lib
>>> PetscDLLibraryRetrieve() // FIRST call
>>> PetscDLLibraryRetrieve() // SECOND call
>> That first use of Retrieve() is probably not needed and should be
>> removed.
>>> However, I'm not sure if this is a real issue. It seems that
>>> ./bin/urlget.py is smart enough as to skip downloading based on
>>> timestamps (though I'm not sure if the same applies to the wget
>>> fallback in 'bin/urlget' shell script)
>>> Lisandro Dalcín
>>> Centro Internacional de Métodos Computacionales en Ingeniería
>>> (CIMEC)
>>> Instituto de Desarrollo Tecnológico para la Industria Química
>>> (INTEC)
>>> Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
>>> PTLC - Güemes 3450, (3000) Santa Fe, Argentina
>>> Tel/Fax: +54-(0)342-451.1594
> Lisandro Dalcín
> Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
> Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
