Independently configuring down & up smoothers in PCMG
    Barry Smith
    bsmith at mcs.anl.gov
    Mon Oct 20 17:18:00 CDT 2008
    Matt,
     You idea is more general than mine, and (I think) encompasses
what you could
do with mine.
     We must keep in mind that prefixes can be append/prepended to
other prefixes
repeatedly. To manage this with your approach we might likely need to
turn a prefix
into a first class object and provide all the infrastructure to manage
them. Yuck, if
we can help it.
Of course, with my approach and several _2_ and _CAP_ in a string the
searches
get more complicated also, there is no free lunch. But I like the
simplicity of
keeping the prefix a simple string.
We could avoid a prefix object if we, for example, divided the
possibilities
with a |, for example my   mg_levels_1_ prefix would be <mg_levels_1_|
mg_levels>
Note each "part" of an combined prefix would need to be separated by
something
like <> so one knows where the | applies.
You write "we let an object have multiple prefixes", this is actually
what my suggestion
does also, but with very limited possible multiples (which I kind of
like, I hate to think
-you_bad_option_pc_type  and -a_totally_different_pc_type mean the
same thing.)
   Barry
On Oct 20, 2008, at 4:56 PM, Matthew Knepley wrote:
> On Mon, Oct 20, 2008 at 4:18 PM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
>> Sorry I haven't responded to this fully.
>> I hate the idea of a hack that is just for this case and a special
>> flag you got to set or pass in.
>> For the _1_, _2_ etc I did the following. If the string in the code
>> has
>> _%d_  (for example _1_) it first checks for an exact match in the
>> list of
>> set options. If it does not find an exact match it removes the _%d_
>> and
>> tries
>> again for an exact match. This seems to work pretty well and could be
>> used in many places in the code, not just in the PCMG stuff.
> I am not sure I like this. It does not fit with my idea of
> namespaces, but I
> do like something very similar (maybe even identical, I can't tell
> yet). What
> if we let an object have multiple prefixes, and we have an order for
> checking.
> The way we could have
>  -pc_mg_1_ksp_max_its 2 -pc_mg_1_up_ksp_max_its 3
> The second would override the first for the up smoother. Is this
> identical to
> what you were proposing?
>  Matt
>> It would be nice to use some similar technique the case below.
>> Possibilities
>> 1) use _CAPS_ first exactly and then removing the _CAPS_
>> 2) make the part with special charactors _<string>_,  first look with
>> _string_
>> then try without _string_ (the <> are just my example charactors,
>> could use
>> | or whatever.
>> What do people think about this?
>>  Barry
>> Note that currently we always use small letters in the option
>> names. We
>> could continue to
>> have the options database have small letters and use
>> _tolower(CAPS)_ as the
>> first test.
>> I'm inclinded to do 1).
>> With multiple _XXX_ _4_ in an option we'll have to be careful to
>> properly
>> check all possibilities
>> in some consistent order.
>> On Oct 8, 2008, at 10:14 PM, Dave May wrote:
>>> Howdy,
>>>    Should there be a mechanism to independently configure the down
>>> and up smoothers
>>> for PCMG from the command line?
>>> From the looks of things, it seems that on a  given level, one is
>>> only
>>> able to set the smoothing
>>> sweeps to be different via
>>>  -pc_mg_smoothup 3 -pc_mg_smoothdown 2
>>> Since both the down and up smoothers (KSP's) have the prefix set
>>> to be
>>> "mg_levels_X",
>>> it would seem that I cannot differentiate between the up ksp at
>>> level
>>> X from the down ksp
>>> at level X via any command line arguments.
>>> It would be pain to ALWAYS have to configure both the up and down
>>> smoothers independently.
>>> But to enable the down and up smoothers to be configured
>>> independently
>>> (on those odd occasions
>>> you want to do it) , could we do something like; set a flag via
>>>  -pc_mg_smoothers_different
>>> which would include in the smoothers prefix, the words "up" or
>>> "down"?
>>> Then on the command line we could do something like
>>>  -mg_levels_1_up_ksp_type XXX
>>>  -mg_levels_1_down_ksp_type YYY
>>> Cheers,
>>>  Dave
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
