now impossible to debug code that uses PETSc shared libraries?
    Barry Smith
    bsmith at mcs.anl.gov
    Fri May  2 16:21:15 CDT 2008
apple
On May 1, 2008, at 11:23 AM, Satish Balay wrote:
> What machine is this?
> Its been working forever for me on linux.
> Satish
> asterix:/home/balay/spetsc/src/ksp/ksp/examples/tutorials>ls /home/
> balay/spetsc/asterix/lib/
> foo                 libpetscdm.so   libpetscmat.so   libpetsc.so
> libpetscvec.so
> libpetsccontrib.so  libpetscksp.so  libpetscsnes.so  libpetscts.so
> <removed .a files>
> asterix:/home/balay/spetsc/src/ksp/ksp/examples/tutorials>ldd ex2
>        linux-gate.so.1 =>  (0x00110000)
>        libpetscksp.so => /home/balay/spetsc/asterix/lib/
> libpetscksp.so (0x00111000)
>        libpetscdm.so => /home/balay/spetsc/asterix/lib/libpetscdm.so
> (0x00374000)
>        libpetscmat.so => /home/balay/spetsc/asterix/lib/
> libpetscmat.so (0x00493000)
>        libpetscvec.so => /home/balay/spetsc/asterix/lib/
> libpetscvec.so (0x00838000)
>        libpetsc.so => /home/balay/spetsc/asterix/lib/libpetsc.so
> (0x00a55000)
>        libX11.so.6 => /usr/lib/libX11.so.6 (0x00bf9000)
>        liblapack.so.3 => /usr/lib/atlas/liblapack.so.3 (0x00cf5000)
>        libblas.so.3 => /usr/lib/atlas/libblas.so.3 (0x02a29000)
>        libm.so.6 => /lib/libm.so.6 (0x009a0000)
>        libpthread.so.0 => /lib/libpthread.so.0 (0x009c9000)
>        libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x00a0e000)
>        libgfortran.so.1 => /usr/lib/libgfortran.so.1 (0x0600e000)
>        libc.so.6 => /lib/libc.so.6 (0x078a3000)
>        libxcb-xlib.so.0 => /usr/lib/libxcb-xlib.so.0 (0x009e2000)
>        libxcb.so.1 => /usr/lib/libxcb.so.1 (0x009e4000)
>        libdl.so.2 => /lib/libdl.so.2 (0x00a00000)
>        /lib/ld-linux.so.2 (0x00a38000)
>        libXau.so.6 => /usr/lib/libXau.so.6 (0x00a05000)
>        libXdmcp.so.6 => /usr/lib/libXdmcp.so.6 (0x00a08000)
> asterix:/home/balay/spetsc/src/ksp/ksp/examples/tutorials>gdb ex2
> GNU gdb Red Hat Linux (6.6-45.fc8rh)
> Copyright (C) 2006 Free Software Foundation, Inc.
> GDB is free software, covered by the GNU General Public License, and
> you are
> welcome to change it and/or distribute copies of it under certain
> conditions.
> Type "show copying" to see the conditions.
> There is absolutely no warranty for GDB.  Type "show warranty" for
> details.
> This GDB was configured as "i386-redhat-linux-gnu"...
> Using host libthread_db library "/lib/libthread_db.so.1".
> (gdb) b MatMult
> Function "MatMult" not defined.
> Make breakpoint pending on future shared library load? (y or [n]) y
> Breakpoint 1 (MatMult) pending.
> (gdb) r
> Starting program: /home/balay/hg-repo/petsc-dev/src/ksp/ksp/examples/
> tutorials/ex2
> [Thread debugging using libthread_db enabled]
> Breakpoint 2 at 0x6250f3: file matrix.c, line 1690.
> Pending breakpoint "MatMult" resolved
> [New Thread -1208318272 (LWP 30748)]
> [Switching to Thread -1208318272 (LWP 30748)]
> Breakpoint 2, MatMult (mat=0x9aabc58, x=0x9a9c888, y=0x9a9d698) at
> matrix.c:1690
> 1690         PetscFunctionBegin;
> Missing separate debuginfos, use: debuginfo-install atlas.i386
> gcc.i386 glibc.i686 libX11.i386 libXau.i386 libXdmcp.i386 libxcb.i386
> (gdb) list
> 1685  @*/
> 1686  PetscErrorCode PETSCMAT_DLLEXPORT MatMult(Mat mat,Vec x,Vec y)
> 1687  {
> 1688    PetscErrorCode ierr;
> 1689
> 1691      PetscValidHeaderSpecific(mat,MAT_COOKIE,1);
> 1692      PetscValidType(mat,1);
> 1693      PetscValidHeaderSpecific(x,VEC_COOKIE,2);
> 1694      PetscValidHeaderSpecific(y,VEC_COOKIE,3);
> (gdb)
> On Thu, 1 May 2008, Barry Smith wrote:
>> It seems to now be impossible to debug in code that uses PETSc shared
>> libraries
>> 	        fi; \
>> 	        if [ "$$flag" != "" ]; then \
>>               echo "building $$LIBNAME.${SL_LINKER_SUFFIX}"; \
>>                 ${RM} -f ${INSTALL_LIB_DIR}/tmp-petsc-shlib/*; \
>> 	          cd  ${INSTALL_LIB_DIR}/tmp-petsc-shlib; \
>> 	          ${AR} x ${INSTALL_LIB_DIR}/$$LIBNAME.${AR_LIB_SUFFIX}; \
>>                 cd $$cwd;\
>> 	          ${OMAKE} LIBNAME=$$LIBNAME
>> SHARED_LIBRARY_TMPDIR=${INSTALL_LIB_DIR}/tmp-petsc-shlib
>> shared_arch; \
>> 	        fi; \
>> 	      fi; \
>> 	    done; \
>> 	    ${RM} -rf ${INSTALL_LIB_DIR}/tmp-petsc-shlib; \
>> 	  fi
>> In the debugger, of course, one gets
>> warning: Could not find object file
>> "/Users/bsmith/Src/petsc-dev-for-fixes/shit/lib/tmp-petsc-shlib/
>> bvec2.o" - no
>> debug information available for "bvec2.c".
>> since the .o files are removed the debugger cannot find any debug
>> information.
>> Is this intentional? Seems pretty terrible to give up debugging
>> just to use
>> shared libraries.
>>  Barry
