now impossible to debug code that uses PETSc shared libraries?
Matthew Knepley
knepley at gmail.com
Thu May 1 10:26:01 CDT 2008
I can also debug just fine or I would scream bloody murder.
Matt
On Thu, May 1, 2008 at 10:23 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> What machine is this?
> Its been working forever for me on linux.
> Satish
> asterix:/home/balay/spetsc/src/ksp/ksp/examples/tutorials>ls /home/balay/spetsc/asterix/lib/
> foo libpetscdm.so libpetscmat.so libpetsc.so libpetscvec.so
> libpetsccontrib.so libpetscksp.so libpetscsnes.so libpetscts.so
> <removed .a files>
> asterix:/home/balay/spetsc/src/ksp/ksp/examples/tutorials>ldd ex2
> linux-gate.so.1 => (0x00110000)
> libpetscksp.so => /home/balay/spetsc/asterix/lib/libpetscksp.so (0x00111000)
> libpetscdm.so => /home/balay/spetsc/asterix/lib/libpetscdm.so (0x00374000)
> libpetscmat.so => /home/balay/spetsc/asterix/lib/libpetscmat.so (0x00493000)
> libpetscvec.so => /home/balay/spetsc/asterix/lib/libpetscvec.so (0x00838000)
> libpetsc.so => /home/balay/spetsc/asterix/lib/libpetsc.so (0x00a55000)
> libX11.so.6 => /usr/lib/libX11.so.6 (0x00bf9000)
> liblapack.so.3 => /usr/lib/atlas/liblapack.so.3 (0x00cf5000)
> libblas.so.3 => /usr/lib/atlas/libblas.so.3 (0x02a29000)
> libm.so.6 => /lib/libm.so.6 (0x009a0000)
> libpthread.so.0 => /lib/libpthread.so.0 (0x009c9000)
> libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x00a0e000)
> libgfortran.so.1 => /usr/lib/libgfortran.so.1 (0x0600e000)
> libc.so.6 => /lib/libc.so.6 (0x078a3000)
> libxcb-xlib.so.0 => /usr/lib/libxcb-xlib.so.0 (0x009e2000)
> libxcb.so.1 => /usr/lib/libxcb.so.1 (0x009e4000)
> libdl.so.2 => /lib/libdl.so.2 (0x00a00000)
> /lib/ld-linux.so.2 (0x00a38000)
> libXau.so.6 => /usr/lib/libXau.so.6 (0x00a05000)
> libXdmcp.so.6 => /usr/lib/libXdmcp.so.6 (0x00a08000)
> asterix:/home/balay/spetsc/src/ksp/ksp/examples/tutorials>gdb ex2
> GNU gdb Red Hat Linux (6.6-45.fc8rh)
> Copyright (C) 2006 Free Software Foundation, Inc.
> GDB is free software, covered by the GNU General Public License, and you are
> welcome to change it and/or distribute copies of it under certain conditions.
> Type "show copying" to see the conditions.
> There is absolutely no warranty for GDB. Type "show warranty" for details.
> This GDB was configured as "i386-redhat-linux-gnu"...
> Using host libthread_db library "/lib/libthread_db.so.1".
> (gdb) b MatMult
> Function "MatMult" not defined.
> Make breakpoint pending on future shared library load? (y or [n]) y
> Breakpoint 1 (MatMult) pending.
> (gdb) r
> Starting program: /home/balay/hg-repo/petsc-dev/src/ksp/ksp/examples/tutorials/ex2
> [Thread debugging using libthread_db enabled]
> Breakpoint 2 at 0x6250f3: file matrix.c, line 1690.
> Pending breakpoint "MatMult" resolved
> [New Thread -1208318272 (LWP 30748)]
> [Switching to Thread -1208318272 (LWP 30748)]
> Breakpoint 2, MatMult (mat=0x9aabc58, x=0x9a9c888, y=0x9a9d698) at matrix.c:1690
> 1690 PetscFunctionBegin;
> Missing separate debuginfos, use: debuginfo-install atlas.i386 gcc.i386 glibc.i686 libX11.i386 libXau.i386 libXdmcp.i386 libxcb.i386
> (gdb) list
> 1685 @*/
> 1686 PetscErrorCode PETSCMAT_DLLEXPORT MatMult(Mat mat,Vec x,Vec y)
> 1687 {
> 1688 PetscErrorCode ierr;
> 1689
> 1691 PetscValidHeaderSpecific(mat,MAT_COOKIE,1);
> 1692 PetscValidType(mat,1);
> 1693 PetscValidHeaderSpecific(x,VEC_COOKIE,2);
> 1694 PetscValidHeaderSpecific(y,VEC_COOKIE,3);
> (gdb)
> On Thu, 1 May 2008, Barry Smith wrote:
> > It seems to now be impossible to debug in code that uses PETSc shared
> > libraries
> > fi; \
> > if [ "$$flag" != "" ]; then \
> > echo "building $$LIBNAME.${SL_LINKER_SUFFIX}"; \
> > ${RM} -f ${INSTALL_LIB_DIR}/tmp-petsc-shlib/*; \
> > cd ${INSTALL_LIB_DIR}/tmp-petsc-shlib; \
> > ${AR} x ${INSTALL_LIB_DIR}/$$LIBNAME.${AR_LIB_SUFFIX}; \
> > cd $$cwd;\
> > ${OMAKE} LIBNAME=$$LIBNAME
> > SHARED_LIBRARY_TMPDIR=${INSTALL_LIB_DIR}/tmp-petsc-shlib shared_arch; \
> > fi; \
> > fi; \
> > done; \
> > ${RM} -rf ${INSTALL_LIB_DIR}/tmp-petsc-shlib; \
> > fi
> > In the debugger, of course, one gets
> > warning: Could not find object file
> > "/Users/bsmith/Src/petsc-dev-for-fixes/shit/lib/tmp-petsc-shlib/bvec2.o" - no
> > debug information available for "bvec2.c".
> > since the .o files are removed the debugger cannot find any debug information.
> > Is this intentional? Seems pretty terrible to give up debugging just to use
> > shared libraries.
> > Barry
experiments is infinitely more interesting than any results to which
their experiments lead.
-- Norbert Wiener
