ML with OpenMPI
    Jed Brown
    jed at 59A2.org
    Tue Mar 25 08:59:28 CDT 2008
On Tue 2008-03-25 10:21, Lisandro Dalcin wrote:
> However, I still do not understand why I never had this problem. Jed,
> you built ML yourself, or were you letting PETSc to automatically
> download and build it? Or perhaps I did not noticed the problem
> because of MPICH2?
I let PETSc build it for me.  I think you did not notice the problem because
MPICH2 defines MPI_Comm to be an int which happens to be the same as used by ML
in their dummy MPI so there is no type mismatch.  From the contents of
ml_common.h, it looks like you would still run into trouble if you were using
optional features of ML.  The reason I like OpenMPI is exactly this stronger
type checking and that it seems to crash sooner when I have a bug.
Jed
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20080325/419e69b7/attachment.sig>
