configuring with --prefix
Matthew Knepley
knepley at gmail.com
Fri Mar 21 17:32:15 CDT 2008
On Fri, Mar 21, 2008 at 4:53 PM, Lisandro Dalcin <dalcinl at gmail.com> wrote:
> I got this error at configuration time:
> You do not have write access to create install directory given with
> --prefix=/usr/local/petsc/dev/linux-gnu perhaps use --with-sudo=sudo
> also
> Then I've added, the sudo stuff and worked. However, after the
> configuation, the dir was not created. So the question is: in which
> scenario PETSc does need access to the install dir at configuration
> time?
PETSc does not NEED access until install time, however it is checking because
people often screw this up.
Matt
> Lisandro Dalcín
> Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
> Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
> Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
> PTLC - Güemes 3450, (3000) Santa Fe, Argentina
> Tel/Fax: +54-(0)342-451.1594
experiments is infinitely more interesting than any results to which
their experiments lead.
-- Norbert Wiener
