problem with PetscSynchronizedFPrintf (fwd)
    Matthew Knepley
    knepley at gmail.com
    Mon Jul 21 15:44:39 CDT 2008
On Mon, Jul 21, 2008 at 3:03 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>  Matt,
>    You have to be careful here. You use PetscMalloc() here, are you positive
> this
> routine will never be called BEFORE PetscMalloc() is setup for (sometime in
> PetscInitialize), or after PetscMalloc()
> is taken down (somewhere in PetscFinalize())? Is there someway you can make
> sure that
> it is safe? In a few places on setup I have to use a raw malloc instead of
> PetscMalloc(), I don't
> want you to have to do that here.
>  I'm not saying to change back the code, just to be careful and check it.
I looked at all the code. There are no calls in PetscInitialize() and
I cannot find anything
else that might be called before PetscMalloc is set.
  Matt
>   Barry
> On Jul 21, 2008, at 2:47 PM, Matthew Knepley wrote:
>> I made this change because synchronized printing was cutting off my
>> stuff. Now the queue is dynamically allocated so it can accomodate
>> any size string.
>> I tried ex7 and it runs fine for me, even under valgrind.
>> Shi, can you reproduce this with a Sieve example?
>>  Matt
>> On Mon, Jul 21, 2008 at 2:37 PM, Satish Balay <balay at mcs.anl.gov> wrote:
>>> Looks like this could be related to changeset 9e3fbe04a926
>>> --> mprint.h <--
>>> -  char        string[QUEUESTRINGSIZE];
>>> +  char       *string;
>>> So now strings needs to use malloc()/free()?
>>> Matt - you can reproduce this issue with dm/ao/examples/tests/ex7.c
>>> Satish
>>> On Mon, 21 Jul 2008, Satish Balay wrote:
>>>> ---------- Forwarded message ----------
>>>> Date: Sun, 20 Jul 2008 22:39:13 -0700 (PDT)
>>>> From: Shi Jin <jinzishuai at yahoo.com>
>>>> Subject: problem with PetscSynchronizedFPrintf
>>>> To: petsc-dev at mcs.anl.gov
>>>> Hi,
>>>> I recently updated my petsc-dev and found my previously working code is
>>>> having trouble running in parallel. I've narrowed it down to the calls to
>>>> PetscSynchronizedFPrintf. Even if I don't have those, I will have errors at
>>>> the end of my MPI runs like:
>>>> [1]PETSC ERROR: PetscMemzero() line 189 in src/sys/utils/memc.c
>>>> [1]PETSC ERROR: PetscViewerASCIISynchronizedPrintf() line 859 in
>>>> src/sys/viewer/impls/ascii/filev.c
>>>> [1]PETSC ERROR: PetscMemoryShowUsage() line 367 in src/sys/memory/mtr.c
>>>> [1]PETSC ERROR: PetscFinalize() line 675 in src/sys/objects/pinit.c
>>>> [1]PETSC ERROR: completeSection() line 163 in main.cxx
>>>> [0]0:Return code = 0, signaled with Interrupt
>>>> [0]1:Return code = 85
>>>> Since the same code was running fine before the update. I am wondering
>>>> if it is something recently introduced.
>>>> Thanks a lot.
>>>> Shi Jin, PhD
>> experiments is infinitely more interesting than any results to which
>> their experiments lead.
>> -- Norbert Wiener
-- Norbert Wiener
