possible bug?
    Barry Smith
    bsmith at mcs.anl.gov
    Wed Dec 17 15:19:41 CST 2008
   The code is correct in petsc-dev.
   Barry
On Dec 17, 2008, at 3:05 PM, David Fuentes wrote:
> working with petsc-2.3.3-p13
> in file $PETSC_DIR/src/vec/vec/impls/mpi/pdvec.c
> possible bug in VecSetValues_MPI
> DIPWS019$ diff $PETSC_DIR/src/vec/vec/impls/mpi/pdvec.c   pdvec.c
> 878c878
> <         if (ix[i] > xin->map.N)
> SETERRQ2(PETSC_ERR_ARG_OUTOFRANGE,"Out
> of range index value %D maximum %D",ix[i],xin->map.N);
>>        if (ix[i] >= xin->map.N)
>> SETERRQ2(PETSC_ERR_ARG_OUTOFRANGE,"Out of range index value %D
