[TAO Comments #456] Re: BuildSystem for PETSc+TAO
Jason Sarich
sarich at mcs.anl.gov
Fri Dec 12 14:42:30 CST 2008
We are eventually moving TAO away from the C++ necessity, probably for
next release (after a PETSc-3 compatibile release). I agree with
Barry that now is not the time to start changing PETSc configure.
Jason
On Fri, 12 Dec 2008, Barry Smith wrote:
> On Dec 12, 2008, at 1:50 PM, Lisandro Dalcin wrote:
>> When using petsc-2.3.3+tao-1.9, TAO does require that PETSc be built
>> with C++. I believe this is just because a PETSc built with C cannot
>> always provide enough info to TAO makefiles about the C++ compiler...
>> However, when PETSc is built with a external that requires C++/mpicxx,
>> then it seems some C++ stuff is configured even when core PETSc is
>> compiled with C/mpicc.
> This is true.
>> IMHO, this is a bit annoying, and could be done better and probably
>> with no too much work...
> What is annoying, that "some C++ stuff is configured even when core PETSc
> is
>> compiled with C/mpicc." or that "TAO does require that PETSc be built
>> with C++."
>> Could PETSc BuildSystem try to configure both C and C++ despite the
>> actual value of --with-clanguage ?? Does this make sense?
> In theory, of course, this is trivial. Because of its origins, BuildSystem
> was
> not designed to do a full proper configuration for both C and C++. It
> would take some monkeying with the code and yes we cannot do that
> before the release.
> Barry
>> Lisandro Dalcín
>> Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
>> Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
>> Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
>> PTLC - Güemes 3450, (3000) Santa Fe, Argentina
>> Tel/Fax: +54-(0)342-451.1594
