Inner KSP never created on SNES
Lisandro Dalcin
dalcinl at gmail.com
Tue Dec 2 16:02:50 CST 2008
However, the argument (at source code) that PCGetOperators should
return new Mat's if they were never set never, never convinced me. For
me, Mat's are to KSP/PC like Function/Jacobian to SNES. Stuff that the
user has to provide. Supose you call PCGetOperators(), and then that
call returns a just created Mat, with no sizes and not type, almost
empty. What those returned Mat's would be good for?? Just to save
users from a MatCreate() call ?? However, creating 'on-demand' inner
PC on KSP, or inner KSP on SNES is a completelly different matter, as
we can provide meaningful defaults for SNESType/KSPType/PCType.
On Tue, Dec 2, 2008 at 6:53 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> Ugg, I have added this check.
> Barry
> This bug came from another "design extension" that was slightly
> half-assed.
> Originally SNESCreate() always created a KSP and KSPCreate() always created
> a PC and one could not change them. But I realized that PCCreate() did not
> automatically have a Mat in it, you had to add one with PCSetOperators()
> [which really should be called PCSetMats()!] One could also change
> it later with another call to PCSetOperators(). By symmetry one should
> also be able to replace the KSP in a SNES and the PC in a KSP, hence
> SNESSetKSP(), KSPSetPC().
> But still PC's PCGetOperator() was different
> because it returned nothing if PCSetOperators() had not yet been set. So
> I had PCGetOperators() automatically return a new Mat if one had never set
> it. I then changed SNESGetKSP() and KSPGetPC() to automatically create
> one if it did not already exist and SNESSetKSP() had never been called.
> This meant I had to add a bunch of checks if (!snes->ksp) to make
> sure SNES had a proper KSP when needed.
> An alternative approach was to have SNESCreate() and KSPCreate()
> continue to create the KSP and PC and change the PCCreate() to automatically
> have a Mat (then PCSetOperators() would just overwrite the one already
> there). The reason I didn't take this route is that PC hast TWO slots for
> mat and pmat, sometimes they are the same and sometimes they are
> different. Should PCCreate() create one and put it in both slots or create
> two, one for each slot. I could avoid that decision by having the creation
> of those mats until PCGetOperators() when the user decides they want two or
> one matrices by passing the same address in for mat and pmat or different
> addresses.
> So a bunch of design decisions over time lead to the current undesirable
> need for if (!snes->ksp) ....
> On Dec 2, 2008, at 8:08 AM, Lisandro Dalcin wrote:
>> I've just noticed that now SNES does not create the inner KSP at the
>> time SNESCreate() is called. Then I could easily manage to break
>> things (basically, if SNESSetFromOptions() is never called)
>> Does it make sense to add:
>> if (!snes->ksp) { SNESGetKSP(snes, &snes->ksp);}
>> near the begining of SNESSetUp() ??
>> Lisandro Dalcín
>> Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
>> Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
>> Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
>> PTLC - Güemes 3450, (3000) Santa Fe, Argentina
>> Tel/Fax: +54-(0)342-451.1594
Lisandro Dalcín
