finished changes for solving strict aliasing issue
Barry Smith
bsmith at mcs.anl.gov
Tue Oct 2 14:51:23 CDT 2007
I cloned from petsc-dev; you should just change the parent in
the file repositorydirectory/.hg/hgrc and then do an hg push
Barry
There are no petsc-dev-* lying around.
On Tue, 2 Oct 2007, Lisandro Dalcin wrote:
> Thanks, Barry... Just to know: this a default setup? Or you just
> created a clone for me?
> On 10/2/07, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > Lisandro,
> > You should be able to push into petsc-dev-dalcinl, then anyone will be able
> > to pull from that.
> > Barry
> > > Not sure if any of you had the time to look at the small example I sended
> > > to show the strict aliasing issue.
> > > Anyway, I finished the changes needed to solve this issue, all C and
> > > Fortran examples pass. If -Wno-strict-aliasing is removed, GCC will
> > > still complain in many parts, but now we are sure that it will not
> > > generate bad code when using PetscObject and derived structures. BTW,
> > > I commented out all thos XXX_Publish() routines. Is this feature used
> > > in any way? perhaps some external code? If this still have to be
> > > supported, perhaps I can change PetscHeaderCreate() to pass the
> > > publish routine.
> > > Could you create a petsc-dev clone in the hg server in order I can
> > > push this for your to review?
> > > Regards,
> > > PD: Many thanks to Stephan for his 'sed' tip. It was of great help for
> > > this to be finished.
