finished changes for solving strict aliasing issue
    Lisandro Dalcin
    dalcinl at gmail.com
    Tue Oct  2 14:48:16 CDT 2007
Thanks, Barry...  Just to know: this a default setup? Or you just
created a clone for me?
On 10/2/07, Barry Smith <bsmith at mcs.anl.gov> wrote:
>    Lisandro,
>     You should be able to push into petsc-dev-dalcinl, then anyone will be able
> to pull from that.
>    Barry
> On Tue, 2 Oct 2007, Lisandro Dalcin wrote:
> > Not sure if any of you had the time to look at the small example I sended
> > to show the strict aliasing issue.
> > Anyway, I finished the changes needed to solve this issue, all C and
> > Fortran examples pass. If -Wno-strict-aliasing is removed, GCC will
> > still complain in many parts, but now we are sure that it will not
> > generate bad code when using PetscObject and derived structures. BTW,
> > I commented out all thos XXX_Publish() routines. Is this feature used
> > in any way? perhaps some external code? If this still have to be
> > supported, perhaps I can change PetscHeaderCreate() to pass the
> > publish routine.
> > Could you create a petsc-dev clone in the hg server in order I can
> > push this for your to review?
> > Regards,
> > PD: Many thanks to Stephan for his 'sed' tip. It was of great help for
> > this to be finished.
Lisandro Dalcín
Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
PTLC - Güemes 3450, (3000) Santa Fe, Argentina
Tel/Fax: +54-(0)342-451.1594
