warn message in log summary
Richard Tran Mills
rmills at ornl.gov
Mon Nov 26 10:25:57 CST 2007
Lisandro,
Unfortunately, I see the same negative timings problem on the Cray XT3/4
systems when I configure PETSc to use MPI_Wtime() for all its timings. So
that doesn't necessarily fix anything...
--Richard
Lisandro Dalcin wrote:
> Perhaps PETSc should use MPI_Wtime as default timer. If a better one
> is available, then use it. But then MPIUNI have to also provide an
> useful, default implementation.
> Runing a simple test, like this (MPICH2):
> int main(void)
> int i;
> double t0[100],t1[100];
> MPI_Init(0,0);
> for (i=0; i<100; i++) {
> t0[i] = MPI_Wtime();
> t1[i] = MPI_Wtime();
> for (i=0; i< 100; i++) {
> printf("t0=%e, t1=%e, dt=%e\n",t0[i],t1[i],t1[i]-t0[i]);
> MPI_Finalize();
> return 0;
> and in the SAME box I get the PETSc warning, it consistently gives me
> positive time deltas of the order of MPI_Wtick()...
