warn message in log summary
Lisandro Dalcin
dalcinl at gmail.com
Mon Nov 26 10:20:55 CST 2007
On 11/24/07, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > To minor question about this message:
> > * What means 'to rapid calls'? Is it a typo? Should be 'too rapid
> > calls' ?
> Yup
> > * Perhaps a newline could be added after the warn mesage?
> Yup
Then I'll fix the formating.
> I hate this message and problem, I wish there was a real fix.
Perhaps PETSc should use MPI_Wtime as default timer. If a better one
is available, then use it. But then MPIUNI have to also provide an
useful, default implementation.
Runing a simple test, like this (MPICH2):
int main(void)
int i;
double t0[100],t1[100];
MPI_Init(0,0);
for (i=0; i<100; i++) {
t0[i] = MPI_Wtime();
t1[i] = MPI_Wtime();
for (i=0; i< 100; i++) {
printf("t0=%e, t1=%e, dt=%e\n",t0[i],t1[i],t1[i]-t0[i]);
MPI_Finalize();
return 0;
and in the SAME box I get the PETSc warning, it consistently gives me
positive time deltas of the order of MPI_Wtick()...
> > Lisandro Dalcín
> > Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
> > Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
> > Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
> > PTLC - Güemes 3450, (3000) Santa Fe, Argentina
> > Tel/Fax: +54-(0)342-451.1594
Lisandro Dalcín
