jaguar and mercurial
Richard Tran Mills
rmills at ornl.gov
Tue Nov 6 16:30:17 CST 2007
The problem was that the PETSc configuration files didn't have
PETSC_HAVE_F90_2PTR_ARG defined so the F90 interfaces weren't working
correctly. I think this has been fixed for the 'cray-xt3-cnl_g' and
'cray-xt3-cnl_fast' architectures. I have to leave the office right now and I
will recompile the other architectures tonight.
Give things a try and let me know if they are broken.
--Richard
Richard Tran Mills wrote:
> PETSc has been built for CNL. Use
> PETSC_DIR=/apps/PETSC/petsc-2.3.3-hg
> and PETSC_ARCH=cray-xt3-cnl_g (debugging) OR
> cray-xt3-cnl_fast (most aggressive optimization)
> cray-xt3-cnl_O3 (-O3 optimization)
> cray-xt3-cnl_O2 (-O2 optimization)
> All of the example PETSc codes I have tried work, but PFLOW is dying
> with a seg fault on the simple THC example. I am currently trying to
> figure the problem.
