Compiling on Solaris 10 for X86
Thu May 10 11:30:51 CDT 2007
> if test -e ex19.exe; then /usr/bin/rm -f ex19.exe; fi
Looks like this is an issue with /bin/sh on solaris [and with test
command supported by it]. Our solaris build appears to pick up
/usr/xpg4/bin/sh and the build works fine with it.
Satish
On Thu, 10 May 2007, Matthew Knepley wrote:
> Nothing is wrong with the PETSc build or libraries. However, your make
> (probably not gmake) has a problem with the make rule that cleans up files
> in bmake/common/rules:359. You can just ignore it (or tell us what is wrong).
>  Thanks,
>     Matt
> On 5/10/07, Yi-Feng Adam Zhang <Adam.Zhang at sun.com> wrote:
> > Hi all,
> > Recently I am compiling the PETSc 2.3.2 -P10 on Solaris 10 for X86 with
> > GCC and Sun's f90.
> > Here is the command I give to configure.py:
> > ./config/configure.py --download-f-blas-lapack=1 --with-mpi=0
> > Yes. I don't use the MPI intendedly.  Because I want to make sure every
> > thing is ok before using MPI.
> > When I input the command "make all", every  thing looks fine.
> > But when I try to use "make test" to verify, I get the following error:
> > -bash-3.00# more test_log_solaris2.10-c-debug
> > Running test examples to verify correct installation
> > C/C++ example src/snes/examples/tutorials/ex19 run successfully with 1
> > MPI process
> > Graphics example src/snes/examples/tutorials/ex19 run successfully with
> > 1 MPI process
> > sh: test: argument expected
> > *** Error code 1 (ignored)
> > The following command caused the error:
> > if test -e ex19.ilk; then /usr/bin/rm -f ex19.ilk; fi
> > if test -e ex19.pdb; then /usr/bin/rm -f ex19.pdb; fi
> > if test -e ex19.tds; then /usr/bin/rm -f ex19.tds; fi
> > Fortran example src/snes/examples/tutorials/ex5f run successfully with 1
> > MPI process
> > if test -e ex5f.exe; then /usr/bin/rm -f ex5f.exe; fi
> > if test -e ex5f.ilk; then /usr/bin/rm -f ex5f.ilk; fi
> > if test -e ex5f.pdb; then /usr/bin/rm -f ex5f.pdb; fi
> > if test -e ex5f.tds; then /usr/bin/rm -f ex5f.tds; fi
> > Completed test examples
> > Does anyone have any suggestion?  Thanks in advance!
> > Regards,
> > Adam
